Barrel Style Leather Bottle
  • Please log in to reply
9 replies to this topic
#1 Aghrivaine
Aghrivaine
    Member
  • PipPip
  • 18 posts
Posted 14 January 2013 - 12:19 AM
My latest attempt. Hey, at least it's water-tight!
#2 Aghrivaine
Aghrivaine
    Member
  • PipPip
  • 18 posts
Posted 14 January 2013 - 02:32 PM
Weird, the attached picture isn't showing up. I'll try again.Attached File  leatherbottle.jpg   478.75KB   306 downloads
#3 mikesmith648
mikesmith648
    Leatherworker
  • PipPipPip
  • 576 posts
  • Gender:Male
  • Interests:My Wife, Hunting, Fishing, Leatherwork, Emergency Room Nursing, Cooking, Dogs, and of course....the cat. Also my daughter and my granddaughter, my step daughter and her baby!!
  • Leatherwork Specialty:Sheridan mostly but will dabble in anything!!
  • Interested in learning about:Braiding, and how to deal with stupid people! The braiding is starting to come along, but every solution I find for the Stupid people they have outlawed!!
Posted 14 January 2013 - 04:27 PM
thats different!
Emergency Room Nurse by profession.......Leatherworker at heart!!
Hoping to reverse the order in that one of these days!!
#4 Matt S
Matt S
    Member
  • PipPip
  • 289 posts
  • Gender:Male
Posted 14 January 2013 - 04:58 PM
Looks very functional! These used to be called costrels, from 'costra' meaning rib and the diminuative suffix; a small vessel for carryng by the ribs. It used to be widely considered bad luck to carry cider in anything mineral like ceramics so wooden (vegetable) or leathern (animal) containers were used in stead.
#5 Aghrivaine
Aghrivaine
    Member
  • PipPip
  • 18 posts
Posted 21 January 2013 - 01:30 PM
Wow! I did not know that, but I'm glad you told me. Very cool, thanks!
#6 mark stotesbury
mark stotesbury
    New Member
  • Pip
  • 3 posts
  • Interests:bushcraft,fishing,spincasting
  • Interested in learning about:leather
Posted 22 January 2013 - 02:04 AM
please can you go through the steps to waterproof your barrel also did you get the pattern off the web or is it your own desighn . I made a ''drinking skin'' some one told me to use barley and water to shape it , works really well if you want a barley filled drinking skin - cant get the wet berley thats now set to concrete out of the middle .
#7 Aghrivaine
Aghrivaine
    Member
  • PipPip
  • 18 posts
Posted 22 January 2013 - 11:33 AM
I'll be happy to go in a little more detail, but let me say - I'm a beginner, not an expert at all, and other people here know better than me and make better stuff.
Second, check out here for tradtional costrel methods of construction and patterns: http://leatherworkin...oke-of-leather/
What I did was take a 3" PVC pipe cap, and wet form some fairly thin veg-tan leather over it. I held it in place with a ratcheting metal pipe collar.
When the cap had dried, I trimmed it down to an even 1" edge.
I made a pattern out of paper for the body. I suppose I could have used high school geometry to figure out the circumference of a 3" diameter circle, but I use the prosaic method of a measuring tape.
The long edge of the pattern was the circumference of the circle, plus about 4" on top to cut and shape the spout and carrying-strap slots from.
I measured the paper pattern against the leather edge caps, and it all fit, so I cut it out of leather.
I marked the edges with a pricking wheel for where I was going to sew later.
I used that really strong rubber-cement type glue you can get at Tandy to glue it all together. I held it in place while it dried with clips from the office - those kinds with a metal body and little handles you fold back to open the clip? That kind.
Once it dried (I let it sit for a day) I pulled it out. Al Stohlman forgive me, but I used a Dremel to drill the holes where the pricking wheel had left marks, removing clips as I got to them.
I sewed everything together. I chose artificial sinew because I think it looks cool.
I got the mouth of the costrel wet so the leather would stretch, and put a 1" diameter dowel in while it dried. It took some work to get the dowel in there, but it's important that your spout be nicely formed and about the size to get a cork in to properly seal it.
When the leather had dried (about a day) I sealed it.
Now, I have found three methods for sealing leather vessels; brewer's pitch, wax and epoxy. Brewer's pitch on the inside and wax on the outside is traditional.
I personally prefer expoxy because it's easier and can be used for both hot and cold liquids. (within reason)
I do have an old crockpot full of beeswax, and I do sometimes use both wax and epoxy, especially if I've really botched the stitching and need to plug some holes.
With beeswax, get it just melted and not much hotter, or you'll cook the leather. Dip the leather until it stops bubbling, and then wipe off the excess wax.
Epoxy is much easier. I use Enviro-Tex lite, which is intended for food prep surfaces and non-toxic. Mix up about an ounce or two of expoxy.
Pour it in to your vessel, and put it on wax paper. The epoxy will flow to the bottom, so after about ten minutes turn it on its side, then repeat at every angle to get a nice even coating.
It takes about 8 hours to harden and 72 hours to completely cure. You can test waterproof properties after 8 hours, but if you see little puddles of expoxy on your wax paper, you'll know there were some holes.
No worries, it usually takes two or three coats anyway. The epoxy will eventually seep into all the pores of your leather, and color the exterior, too. I don't usually bother dyeing the leather - the picture above is uncolored, that's just the epoxy.
Important safety tip - don't put a cork in the mouth while there's epoxy drying!
#8 ReneeCanady
ReneeCanady
    Member
  • PipPip
  • 467 posts
  • Gender:Female
  • Leatherwork Specialty:Leather mugs
  • Interested in learning about:Everything
Posted 05 February 2013 - 08:09 AM
Ha! That is awesome! I have never seen one done like that :) I really like it's rustic look as well.
#9 Peter Darby
Peter Darby
    Member
  • PipPip
  • 154 posts
  • Interests:Leatherwork, Medieval re-enactment, traditional archery,
  • Leatherwork Specialty:medeival reproductions
  • How did you find leatherworker.net?:browsing
Posted 05 February 2013 - 08:35 PM
Mark, The envirotex is a great sealer. I have a jack I use for everything from hot coffee to Beer. Barley! Someone doesn't like you. When I am making a bottel I first case the leather then I use playground sand (clean). Fill the bottel anduse a dowel to tamp it down. When you get some space pour in more sand then more tamping. Eventually the leather will stretch out nicely. Let dry and pour out the sand. Whack it around a bit to get out as much as possible. When you put in the sealer any loose grains will be sealed up and not a problem. If you want to see some examples of period costrels and bottels the images from a google search are good. The Froisert paintings also have several examples from canteen size to party size.
#10 ReneeCanady
ReneeCanady
    Member
  • PipPip
  • 467 posts
  • Gender:Female
Posted 08 February 2013 - 12:51 PM
Yeah, Barley is what I used also when making a cantine. Well....barley and a few nuts to shake the barley out lol.
Similar Topics Collapse
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
