Question On Bobbin Mess
  • Please log in to reply
2 replies to this topic
#1 loopinluke
loopinluke
    Member
  • PipPip
  • 37 posts
  • Gender:Male
  • Leatherwork Specialty:Chaps, chinks, etc.
  • Interested in learning about:All facets of leather work.
  • How did you find leatherworker.net?:google
Posted 07 February 2013 - 11:47 PM
I have a Ferdco 1010, and generally have pretty good luck with it. The issue I am having lately is that whenever I get to the end of a line of stitching which is next to something like a buckle, riggin plate, etc., and turn around and backstitch 3 or 4 stitches, the top side of the stitches are great, but the bottom side turns into a big wadded up mess. It lookes like the thread coming from the top gets a kink in it and so doesn't pull the lock back up in the middle of the leather. Does anyone have any ideas on this? Otherwise the stitches look great. I should mention that most of the time when this happens it is where the leather is a little thicker after having wrapped around a buckle etc. I would sure appreciate any help you could give me.
#2 CowboyBob
CowboyBob
    Sewing Machine Dealer
  • PipPipPipPip
  • 1,517 posts
  • Gender:Male
  • Interests:We sell New & Used
    Leather Sewing Machines
    Parts,Needles &Thread
  • Leatherwork Specialty:Can help w/sewing machine questions & supplies
  • Interested in learning about:People needing help with machines
Posted 08 February 2013 - 07:34 AM
I'm not sure what machine the 1010 is BUT it's tension related & probably one of 3-things,the first thing to try is cleaning the thread discs out because lint will build up in there & give you loose tension,#2 can be on the thickness your tension is being released from sewing so thick & #3 is hook timing.
So the easiest thing to try is cleaning the tension try that out & see what happens.
Bob Kovar
Toledo Industrial Sewing Machine Sales Ltd.
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
#3 gottaknow
gottaknow
    Leatherworker
  • PipPipPip
  • 546 posts
  • Gender:Male
  • Interests:Art, music, sewing, photography, gardening
  • Leatherwork Specialty:Industrial sewing machines since 1980, head mechanic for CC Filson.
  • Interested in learning about:ironicly, hand sewing, leather carving and stamping
  • How did you find leatherworker.net?:friend
Posted 08 February 2013 - 07:28 PM
Couple of other things to check. The presser foot has to remain firmly on the leather. When turning around to back stay, make sure there is no space between the top of the leather and the bottom of the foot. Likewise the leather should be flat against the throat plate.
Also check to see if the tension is releasing when you lift the foot to turn. It's fine if it does, but before you start sewing again make sure the needle thread is seated back in the tension. If not, set the foot back down and pull the thread all the way back into the disc before you start sewing again.
Regards, Eric
Similar Topics Collapse
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
