three-legged stool leather
  • Please log in to reply
6 replies to this topic
#1 trastu
trastu
    Member
  • PipPip
  • 118 posts
  • Gender:Male
  • How did you find leatherworker.net?:BUSCANDO TRENZAS DE CUERO
Posted 17 September 2008 - 08:25 AM
please, you know where to find patterns to make three-legged stool leather. what interests me is to know how they joined the legs. thank you very much. Posted Image
#2 whinewine
whinewine
    Leatherworker.net Regular
  • PipPipPipPip
  • 1,085 posts
  • Gender:Male
  • Interests:Leather, photography, writing, stuff...
Posted 17 September 2008 - 08:31 AM
In the tandy kits, anyway, there was a special 'tri bolt' that was used to fasten the legs together. People have made their own with 3 eyebolts, either bolted together, or welded together. Only problem is that the hole position in each leg is drilled to a different height; therefore, you cannot interchange the legs.
russ
#3 UKRay
UKRay
  • PipPipPipPip
  • 1,913 posts
  • Gender:Male
  • Interests:Looking, listening and learning
  • Leatherwork Specialty:none
  • Interested in learning about:Everything!
  • How did you find leatherworker.net?:search engine
Posted 17 September 2008 - 01:41 PM
Here you go Trastu - I just had a batch of these tribolts made by a local metalworker - cost was about $6.50 each including materials and delivery.
It is probably easiest to copy the picture and take it with you to the blacksmith. Just tell the guy each leg needs to be
40mm or slightly less than 2 inches… Note: Each threaded ‘leg’ needs to be big enough to go right through a thick bit of broomstick.
Broomstick legs should be about 24" long drilled halfway down to take tribolt. Make your leather 'cap' to whatever size you feel fits best. This is my pattern which you are welcome to copy if you choose.
"Some mornings, it's just not worth chewing through the leather straps"
Ray Hatley
www.barefootleather.co.uk
#4 trastu
trastu
    Member
  • PipPip
  • 118 posts
  • Gender:Male
Posted 17 September 2008 - 02:52 PM
In the tandy kits, anyway, there was a special 'tri bolt' that was used to fasten the legs together. People have made their own with 3 eyebolts, either bolted together, or welded together. Only problem is that the hole position in each leg is drilled to a different height; therefore, you cannot interchange the legs.russ
Thank you very much for the answer. A Greetings from ASTURIAS
Here you go Trastu - I just had a batch of these tribolts made by a local metalworker - cost was about $6.50 each including materials and delivery. It is probably easiest to copy the picture and take it with you to the blacksmith. Just tell the guy each leg needs to be 40mm or slightly less than 2 inches… Note: Each threaded 'leg' needs to be big enough to go right through a thick bit of broomstick. Broomstick legs should be about 24" long drilled halfway down to take tribolt. Make your leather 'cap' to whatever size you feel fits best. This is my pattern which you are welcome to copy if you choose.
Thank you very much for the answer, I find it very helpful. Was exactly what interests me. A Greetings from ASTURIAS
#5 tonyc1
tonyc1
    Leatherworker
  • PipPipPip
  • 989 posts
  • Gender:Male
Posted 18 September 2008 - 07:51 AM
Ray, what diameter are these bolts?
Tony
#6 oldtimer
oldtimer
    Leatherworker
  • PipPipPip
  • 780 posts
  • Gender:Male
  • Leatherwork Specialty:saddles and tack
  • Interested in learning about:all kind of leatherwork
Posted 18 September 2008 - 09:29 AM
Tony
hey Tony
I have a 3 legged stool and the bolts are 6 mm dia.( ~1/4") Make sure the weld is OK ! It hurts to hit the ground on your back! A painful experience ! :-)
"The gun fight at the O.K. corral was actually started by two saddlemakers sitting around a bottle of whiskey talking about saddle fitting"...
#7 UKRay
UKRay
  • PipPipPipPip
  • 1,913 posts
  • Gender:Male
Posted 18 September 2008 - 10:17 AM
hey Tony
Total agreement - my bolts are also 6mm and I'd also advise checking those welds every time.
I originally wanted to do them with polished brass bolts until I found out how much they would cost to make...
Ray Hatley
Similar Topics Collapse
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
