Leatherworker.net: Holster Design (long) - Leatherworker.net
  • (3 Pages)
  • 1
  • 2
  • 3
  • You cannot start a new topic
  • You cannot reply to this topic
Holster Design (long) My take on how to design and construct a holster
#1 User is offline   mattsh Icon
  • Member
  • PipPip
  • Group: Members
  • Gender:Male
  • Interests:God, Missions, Firearms, Knives, Leatherwork, Bladesmith, Gunsmith, Hunting, Fishing, College Football
  • Leatherwork Specialty:Holsters
  • Interested in learning about:Holsters
  • How did you find leatherworker.net?:Google search
Posted 20 October 2008 - 09:16 PM
[Thought that I would at least get the text instructions posted out here. I am working on getting the pictures uploaded.]
I have been on this forum for quite some time. I haven't posted much but I have seen
several people ask about how a holster is made. I am not a professional. I pretty much do
this as a very part time hobby. I thought that I would share the steps I take to design
and make a holster. This particular model is my take on several makers. It is similar to
Alessi's DOJ model. It has a slightly forward cant. I owe all I have learned through
careful study of existing makers and many conversations with Lou Alessi. He has been a
great mentor and friend in sharing his wealth of knowledge on holsters. The following are
the steps I take in design and construction of a holster.
http://img.photobucket.com/albums/v41/mattsh/DSC04907copy.jpg
1. First I lay out the belt line. In this case it is for a 1.25" belt and therefore
I lay out two parallel lines that are 1.5" apart. This allows for the belt loops to
have sufficient room to allow the belt to fit.
http://img.photobucket.com/albums/v41/mattsh/DSC04908copy.jpg
2. I lay the gun on the paper and situate it so that the weight of the gun is balanced on
the belt [not too much below the belt and not too much above the belt]. This usually
equates to the belt running across the trigger guard and part of the breech of the barrel
(as seen in the picture).
http://img.photobucket.com/albums/v41/mattsh/DSC04909copy.jpg
3. I trace the outline of the gun onto the paper.
http://img.photobucket.com/albums/v41/mattsh/DSC04910copy.jpg
4. I lay out the design of the holster and allow "margins" for the space of
stitching and allowance for the thickness of the leather. In this case, being an OWB, I
am using 7/8 oz leather with an exotic overlay that is 2/3 oz. (This was a learning curve
as I have never used exotic before, next time I will use 4/5 oz with the exotic).
Typically I will allow about a 1/4" around the edges of the gun and the belt loops.
The belt loop needs to be far enough away from the gun so that it can be used, yet not
too far away that it wont pull the butt of the gun into your side for concealability (if
that is what you are looking for). One other consideration is that the holster should
provide adequate coverage of the trigger area and the mag release but yet not interfere
with the ability to grip the gun to remove it from the holster. As for the sweat guard, I
like to make mine cover the back end of the slide and be forward enough to cover the
edges of the rear sight.
http://img.photobucket.com/albums/v41/mattsh/DSC04911copy.jpg
5. Here I have cut out the pattern and will trace onto another sheet to make a mirror of
the pattern so it will be 3D.
http://img.photobucket.com/albums/v41/mattsh/DSC04912copy.jpg
6. Here I have flipped the pattern. In laying this out I allow about a 1/2" space at
the bottom and will overlap the patter where the mouth of the holster will wrap around
the gun (which will be at the base of the sweat guard).
http://img.photobucket.com/albums/v41/mattsh/DSC04913copy.jpg
7. Here is the full pattern.
http://img.photobucket.com/albums/v41/mattsh/DSC04914copy.jpg
8. I trace the full pattern onto cardboard. Any typical cardboard box will do. The
cardboard comes in handy because it is a pretty good simulator of leather in thickness
and will give you a good idea of how your holster is going to fit.
http://img.photobucket.com/albums/v41/mattsh/DSC04915copy.jpg
9. The cardboard pattern cut out. After cutting out the pattern I will take a blunt
object and "breakdown" the honeycomb of the cardboard so that it is more
flexible and I can see how the holster is going to fit.
http://img.photobucket.com/albums/v41/mattsh/DSC04916copy.jpg
10. This picture shows how the holster is going to fit.
http://img.photobucket.com/albums/v41/mattsh/DSC04917copy.jpg
11. Now that I have seen how the cardboard holster fits, I lay out the mouth reinforcement
and the belt loop again allowing for the 1.25” belt the stitching marks (which are the inside lines)
are about 2” apart.
http://img.photobucket.com/albums/v41/mattsh/DSC04921copy.jpg
12. I trace the cardboard pattern onto the leather and cut it out with shears. Make sure
that you lay the pattern on the leather correctly for right/left hand use and whether you
want the rough [flesh] side inside or outside. In the past I used a razor knife, but I
have found that shears work better for me. In the tight curves though I still have to use
a razor knife. Also, the shears I use are a pair of straight cut (yellow handle) aluminum
shears, I find that they have better leverage and make cutting very easy.
http://img.photobucket.com/albums/v41/mattsh/DSC04924copy.jpg
13. This picture shows a couple steps later. Pictures would not have shown much. I have
cut out the elephant and glued it to the flesh side of the cow hide so the smooth side is
inside. I have also cut out the mouth/belt loop support piece and glued it together. Also
in this picture you can see that I have laid out the stiching and drilled the holes. The spacing
of the stitches is laid out using a stitch spacer wheel tool with the 5 stitch per inch spacer.
I hand stitch with a saddle stitch. I have found that drilling holes is easier and more uniform
than punching the holes. The stitching is laid out on an 1/8" from the edge. I drilled the holes
with an 5/64" drill bit because it fits my needle.
14. The next step is waxing and slicking the edges that are not stitched, the mouth and muzzle
area of the holster. To wax the edges I melt and use hot parafin wax and use a small brush to
appy the hot wax to the edges. I then use a slicker chucked in a homemade belt driven mandrel.
(Sorry, I could not get a good picture of the edge)
http://img.photobucket.com/albums/v41/mattsh/DSC04931copy.jpg
15. I have prepared the inside edges of the belt loop area for gluing. I use a rasp to
rough up the surface to make it better for the adhering of the surfaces. I have died
the inside of the holster leather now with Angelus Pro Dye using a dauber.
16. After applying the glue I place the glued area of the holster in a bench vise between
two pieces of wood while the glue dries overnight.
http://img.photobucket.com/albums/v41/mattsh/DSC04934copy.jpg
17. Here is a picture of the holster glued together.
http://img.photobucket.com/albums/v41/mattsh/DSC04936copy.jpg
18. Here I have placed some blue painters tape on the area of the holster where I am
going to lay out the stitching. I typically use a 1/4" margin around the form of the
gun to allow enough space for the gun inside the holster.
http://img.photobucket.com/albums/v41/mattsh/DSC04937copy.jpg
19. Here you can see that I have made a mark 1/4" from the edge of the trigger
guard.
20. I complete the layout of the stitching around the edge of the gun and mark the edge
stitching again 1/8" from the edge.
21. Now that the stitching is done, I mold the holster. I typically dunk the holster for
about 20-30 seconds in about a gallon of hot water (about 120 deg) with a drop of dish
soap (this helps break surface tension of the water and allows it to penetrate better).
The leather should not be saturated but should be "cased". To me this means
damp to the touch and will stretch or form with not much effort.
22. If the gun you are using is real for the molding I typically wrap the gun in plastic
wrap before placing it inside the holster. If you are using a dummy gun then just place
the gun inside the holster. I have just started using the rubber "plates" in a
press. I have not yet quite figured this out but it will get better in time. Also at this
time you will want to place a 'wedge' of sorts extending from the front sight back
towards the breech of the barrel to create a tunnel for the front sight so that it does
not pick up any leather as it is removed from the holster which would impede on the use
of the front sight. In this particular holster I did not use this as the natural bend in
the leather created its own tunnel. This is typically not the case and you will want to
create a tunnel for the front sight.
23. After molding the holster any 'boning' can be done. On this particular holster I did
not do any boning.
24. After boning remove the gun from the holster and let it dry overnight.
25. Now punch the belt loop holes. I punch a hole at each end of the slot and then use a
knife to cut between the two. I then use a dremel with a smooth grit sanding drum to
finish the edges.
26. Now finish all of the remaining edges with the wax and burnish.
27. Last step is to apply an acrylic finish. In this case I used a spray can of Leather
Sheen.
http://img.photobucket.com/albums/v41/mattsh/DSC04938copy.jpg
Well, there you have it. I think I covered everything. Like I said, I am no professional,
so hopefully this will conjure up some conversation and others will kick in their tips
and tricks. My main goal was to get a visual reference out here and somehow put it to
words.
This post has been edited by mattsh: 20 October 2008 - 09:38 PM
"Courage brother, do not stumble, though thy path be dark as night: There is a star to guide the humble, trust in God, and do the right. Let the road be dark and dreary and its end far out of sight. Face it bravely, strong or weary. Trust God, and do the right." - General Norman Schwarzkopf
#2 User is offline   Don101 Icon
  • Ambassador
  • PipPipPip
  • Group: Ambassador
  • Gender:Male
  • Interests:Old West Gunleather, Collecting Old West Memorabilia, History of the West, Re-enacting the wild west, Gunspining, Oil painting, and after all that when there is time left over my family.
  • Leatherwork Specialty:gunleather
Posted 20 October 2008 - 11:52 PM
Well congrats on an exelent run through and tutorial on how you do it, thanks that you have taken the time to plan and take pics on the step by step it make ya just want to get in the tack room and have a go, Don
#3 User is offline   paris3200 Icon
  • Member
  • PipPip
  • Group: Members
  • Gender:Male
  • Leatherwork Specialty:Sending leather to the scrap bin.
Posted 21 October 2008 - 07:01 PM
I appreciate you taking the time to outline your steps with pictures. I'm a little curious as to your edging method. It was my understanding that the waxed method was no longer recommended due to the fact that it was prone to wear off. Have you encountered this? If not, how do you prevent it?
#4 User is offline   ArtS Icon
  • Leatherworker.net Regular
  • PipPipPipPip
  • Group: Ambassador
  • Gender:Male
  • Interests:Horse training and trail riding.
  • Leatherwork Specialty:Saddles & Tack
  • Interested in learning about:Everything
Posted 21 October 2008 - 07:37 PM
Thanks! A superb tutorial! I really appreciate it.
Art
Art Schwab
"You cannot teach a man anything. You can only help him discover it within himself." – Galileo Galilei
#5 User is offline   mattsh Icon
  • Member
  • PipPip
  • Group: Members
  • Gender:Male
Posted 21 October 2008 - 09:02 PM
I am glad that you guys like the tutorial. I wish I had made a light box and taken better pictures.
paris - the waxed edge does not really have a surface wax finish to it (so to speak), the wax is in hot liquid form when applied and it soaks into the edge, then when it is burnished it makes a nice hard edge (which I am still trying to perfect). To burnish the edge I have a slicker wheel from Tandys with a bolt through the center of it. I then took an old drill chuck and mounted it to a brass pillar bed mounted mandrel driven by a belt feed from an electric motor. (hmm maybe I should have taken a picture of that). The burnishing gives the edge a nice hard formed look.
If this seems more clear then I will add it to the instructions.
If I can figure out how to get a good picture of a perfect burnished edge (not mine, it was one that Mr. Lou Alessi did) I will post it.
#6 User is offline   TwinOaks Icon
  • Ambassador
  • PipPipPipPip
  • View gallery
  • Group: Ambassador
  • Country:
  • Gender:Male
  • Interests:all of it.
  • Leatherwork Specialty:Too interested in everything to 'specialize' in anything
  • Interested in learning about:Adding some color
  • How did you find leatherworker.net?:Yellow Pages :)
Posted 21 October 2008 - 09:11 PM
Very nice tute for a basic 'askin's avenger' style. This is very well laid out, and the pics help show what you did. Thank you posting this. I think this should probably be pinned so all our guests and new members can easily find it.
Mike D.
"Lazy spider lets dinner guest wreck home"
TwinOaks Leather Website
#7 User is offline   mattsh Icon
  • Member
  • PipPip
  • Group: Members
  • Gender:Male
Posted 21 October 2008 - 09:55 PM
TwinOaks..Thank you for pinning.
#8 User is offline   RustyPhillips Icon
  • Member
  • PipPip
  • Group: Members
  • Gender:Male
  • How did you find leatherworker.net?:google
Posted 22 October 2008 - 04:23 AM
Great writeup!!!! Thanks for putting this together!!
I have been struggling with among other things - how to punch the holes (& hole spacing) - have been doing the two separate sides one at a time & its a little tough (understatement) to get them to line up.
What kind of glue are you using?
When you drill your holes - are you using a drill press or a dremel? And do you drill from the "out side" in, or the "belt side" out?
Im also looking forward to your comments on edge finishing - particularly how you get the two sides to have one edge, but also the waxing & burnishing parts. I'm just about fed up with using a box knife and an orbital sander & badly need to improve this area - I am saving up for another trip to the Tandy store.
And speaking of that trip to the Tandy store - can you take a picture of what you consider to be your minimum essential leather working tools? maybe a second picture with tools that are nice to have but not essential or used infrequently? Im starting out with bare minimum & adding as I go along..... Im always wondering what is the next thing that I need to buy.
This post has been edited by RustyPhillips: 22 October 2008 - 04:26 AM
#9 User is offline   Bree Icon
  • Leatherworker
  • PipPipPip
  • Group: Contributing Member
  • Gender:Female
  • Interests:Motorcycles, Guns, Kayaking, Canoeing, Sewing, Leather, Computers, Website/Application Development
  • Leatherwork Specialty:Biker leather
  • Interested in learning about:Gunleather
Posted 22 October 2008 - 06:27 AM
Excellent addition to the knowledgebase! Great job! Now I need to pull out my XD Blue Gun and make one up for myself!!
:You_Rock_Emoticon: :You_Rock_Emoticon: :You_Rock_Emoticon:
Ride Safe!
Bree
2003 Dyna Wide Glide
Memberships:
Iron Butt Association, Niagara Falls HOG, Wild Fire HOG
NRA, Niagara County Sportsman's Association
#10 User is offline   Echo4V Icon
  • Member
  • PipPip
  • Group: Members
  • Country:
  • Gender:Male
  • Leatherwork Specialty:Learning
  • Interested in learning about:Functional Leatherwork
  • How did you find leatherworker.net?:Webcrawler-search engine
Posted 22 October 2008 - 06:55 AM
First let me say thanks for this tutorial, I have a S&W that I'm wanting to build a pancake for so this will greatly help me. Secondly, I have a question that is related but may be a whole other tutorial...
If you were going to say basket weave stamp your holster, at what step in the process would you do the stamping? I know for tooling you should glue on a backing to keep it from streatching out but what about stamping, will that also stretch the leather?
David
#11 User is offline   mattsh Icon
  • Member
  • PipPip
  • Group: Members
  • Gender:Male
Posted 25 October 2008 - 01:32 PM
Here are some pictures of the homemade setup that I use to burnish the edges. I mounted everything to a 1"x12" board so I can clamp it down to my workbench then unclamp and move it when I am not using it.
http://img.photobucket.com/albums/v41/mattsh/DSC05066copy.jpg
http://img.photobucket.com/albums/v41/mattsh/DSC05067copy.jpg
Here is a bitmap image that I drew that shows what a cross-section picture would look like of an edge.
http://img.photobucket.com/albums/v41/mattsh/edgebitmap.jpg
This post has been edited by mattsh: 25 October 2008 - 01:34 PM
#12 User is offline   mattsh Icon
  • Member
  • PipPip
  • Group: Members
  • Gender:Male
Posted 25 October 2008 - 01:40 PM
Here are some pictures of edges that I was able to get somewhat decent pictures.
These two pictures are of an edge that Lou Alessi did. This is what everyone strives for. Perfectly formed and a nice hard waxed edge.
http://img.photobucket.com/albums/v41/mattsh/DSC05073copy.jpg
http://img.photobucket.com/albums/v41/mattsh/DSC05077copy.jpg
This is a picture of an edge that I burnished. Its not bad but I still have a ways to go.
http://img.photobucket.com/albums/v41/mattsh/DSC05076copy.jpg
#13 User is offline   mattsh Icon
  • Member
  • PipPip
  • Group: Members
  • Gender:Male
Posted 25 October 2008 - 01:45 PM
In response to Rusty here are a couple pictures of the tools that I use the most.
http://img.photobucket.com/albums/v41/mattsh/DSC05070copy.jpg
From left to right: stitch spacing tool, free-hand stitching groove tool, adjustable stitching groove tool, edge beveler
The stitch spacing tool is a 5 stitch per inch and sorry I do not remember the edge beveler size.
http://img.photobucket.com/albums/v41/mattsh/DSC05071copy.jpg
From left to right: hole punch, razor blade knife, rasp, Tanner's Bond Leathercraft Cement
#14 User is offline   mattsh Icon
  • Member
  • PipPip
  • Group: Members
  • Gender:Male
Posted 25 October 2008 - 01:57 PM
Rusty -
You asked about drilling the holes. I find that it works best its makes a cleaner stitch in my opinion. I drill the holes with a drill press. I drill the holes from the outside in.
For finishing the edges I try to get the edge formed like the bitmap picture that I put above. To accomplish this I use a dremel with a drum sander attachment with a medium grit drum and sand the edges to that form. I then apply the hot liquid wax. It soaks in. I then remove any excess wax that may sit "on top" of the edge with a piece of denim in a burnishing type action. I then take it to my edge burnisher and burnish the edge to a nice hard shiny finish.
#15 User is offline   mattsh Icon
  • Member
  • PipPip
  • Group: Members
  • Gender:Male
Posted 26 October 2008 - 12:40 AM
Echo4v - I cannot answer your question I have not done stamping on any holsters. My assumption would be that you would do the stamping after the molding. Hopefully some of the others that have made holsters with stamping will chime in. I know there is a holster maker by name of Tucker that does alot of stamping on his holsters. I think he is on 1911forum and of course is at tuckergunleather.com.
Share this topic:
  • (3 Pages)
  • 1
  • 2
  • 3
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
