Leatherworker.net: Holster Design (long) - Leatherworker.net
  • (3 Pages)
  • 1
  • 2
  • 3
  • You cannot start a new topic
  • You cannot reply to this topic
Holster Design (long) My take on how to design and construct a holster
#16 User is offline   Srigs Icon
  • Member
  • PipPip
  • Group: Members
  • Leatherwork Specialty:Holsters
Posted 26 October 2008 - 01:05 AM
Great overview. Thanks for posting the overview.
Srigs,
http://www.sideguardholsters.com
"If everyone is thinking alike, then somebody isn't thinking" - George S. Patton.
#17 User is offline   okiwen Icon
  • Member
  • PipPip
  • Group: Members
  • Gender:Male
  • Interests:Just about anything I don't know now. As well as being friends with forest animals and prairie dogs.
  • Leatherwork Specialty:Learning to make saddles, holsters and corsets.
  • Interested in learning about:To learn to make the best Holster, Saddle and Tack possible. To know the 'Why' as well as the 'How'.
Posted 26 October 2008 - 02:24 AM
To add to the rest of the people. Thanks for taking the time to do your tutorial. I don't see the photos at work but was still able to follow quite well.
Does anyone differ from this way?
K
Kevin Orr
www.orrleather.com
#18 User is offline   Billsotx Icon
  • Member
  • PipPip
  • Group: Contributing Member
  • Country:
  • Gender:Male
  • How did you find leatherworker.net?:Johanna told me. Is there a better way?
Posted 26 October 2008 - 02:06 PM
View PostEcho4V, on Oct 22 2008, 06:55 AM, said:
First let me say thanks for this tutorial, I have a S&W that I'm wanting to build a pancake for so this will greatly help me. Secondly, I have a question that is related but may be a whole other tutorial...
If you were going to say basket weave stamp your holster, at what step in the process would you do the stamping? I know for tooling you should glue on a backing to keep it from streatching out but what about stamping, will that also stretch the leather?
David
David, I'll chime in since it's been suggested. This probably isn't the only way and it may not be the right way, it's how I go about it. I stamp and/or tool right after I cut out the holster. As you pointed out the leather will stretch once you go to pounding on it - stamping/tooling it. Instead of gluing it to a backing I apply packing tape to the backside. I overlap the strips of tape about 1/2 to 1 inch and I let the ends run out a couple of inches because I'll next tape the whole thing onto a small piece of cardboard - real high tech here an empty cereal, cracker, cookie box ... lol! Can't help it, it's hereditary, my parents were depression kids. You don't have to attach it to a piece of cardboard if it's an entire holster, but that makes working with a mouth band or belt loops easier to handle.
Oops forgot one thing. Before you put the tape on. True up the edges so your borders are nice and even and well defined and also layout your stitch lines, unless you just want to plow through you're work; some folks do that and sometimes it looks ok. Anyway the inside stitch line should end up between two borders in my opinion. That's the way I've seen it done mostly and that's the look I like.
This is not etched in stone: If you're basket stamping (there's a couple of tutorials on the forum) I first use a lined or checkered beveler and bevel around my border on the side I'm going to stamp/tool. Next I'll layout a light mark if I'm basket-weave stamping and then apply all my basket-weave stamping. Then I use a decorative border stamp - a cam or geometric - and when through stamping and while still damp from quick casing I peel the leather off of the tape, not the tape off of the leather. If there's any residual glue and usually there is none from packing tape - rub that off with you fingers or a pencil eraser.
I've seen others apply the beveling after the basket-weave and some even leave the bevel off and just run their border stamps.
I've also seen it pressed, that is molded to the gun and that presses all your stamp impressions out into a remnant of a pattern and I tend to think - why bother to tool.
You can find a link to my web on my profile and go over there and look at a basket-weaved 1911 holster and there's a tooled mouth band on a revolver holster. I working on the site so there's only a page, but it might give you an idea or two.
Hope this helps. ~Bill
#19 User is offline   Jordan Icon
  • Ambassador
  • PipPipPipPip
  • Group: Ambassador
  • Gender:Male
  • Interests:Restoring old Motorbikes, Blues Guitar, Leather work, my hot tub, my health(such as it is), and I owe it all to my lord and savior J.C., he da man!
  • Leatherwork Specialty:Better than some but not as good as most on this site, but it don't deter me at all.
  • Interested in learning about:anything and everything
  • How did you find leatherworker.net?:By Accident just surfing and poof there it was.
Posted 26 October 2008 - 03:00 PM
Fine line as far as wetness for moulding, too wet and you will lose tooling depth and definition, too dry and moulding will not be as crisp around the weapon. There are to many curves and such to stamp after moulding and I have found experimentation is the only way to get it right, but then again, each time it is different. Also I found the better the quality of the leather the easier it is to straddle that fine line. Stohlmans book on holster making has a good description of basketweave process for a western type holster but boning a tight outline of the weapon does not seem to be the usual practice with that type of holster. Ain't leather grand, the fun part for me is trying stuff out and if it doesn't work try a different way. :Lighten: :oops: :bike:
#20 User is offline   MADMAX22 Icon
  • Leatherworker.net Regular
  • PipPipPipPip
  • View gallery
  • Country:
  • Gender:Male
  • Interested in learning about:leather working
  • How did you find leatherworker.net?:searching
Posted 26 October 2008 - 07:41 PM
Yeah and then you get a different peice of leather and its allmost like starting over again LOL.
#21 User is offline   carr52 Icon
  • Leatherworker
  • PipPipPip
  • Gender:Male
  • Interests:I just like to make things. Use to do a little leather work when I was younger and thought I'd give it another try. I had forgotten how much fun it really is.
  • Leatherwork Specialty:none
  • Interested in learning about:all of it
  • How did you find leatherworker.net?:at tandys
Posted 13 November 2008 - 11:00 AM
Here's my first attempt at it. It's a 9mm Keltec P-11. Your right about the learning curve part. I had to cut several paper patterns before i got one i was happy with. On the next one I'll make the belt loop bigger. I had to do alot of streching on this one to get it right but it fits an inch and a half belt kinda snug.
Tom
Attached File  IMG_0085.JPG (597.11K)
Number of downloads: 272Attached File  IMG_0086.JPG (792.52K)
Number of downloads: 251 Attached File  IMG_0084.JPG (521.39K)
#22 User is offline   mattsh Icon
  • Member
  • PipPip
  • Group: Members
  • Gender:Male
  • Interests:God, Missions, Firearms, Knives, Leatherwork, Bladesmith, Gunsmith, Hunting, Fishing, College Football
  • Interested in learning about:Holsters
  • How did you find leatherworker.net?:Google search
Posted 14 November 2008 - 11:41 PM
I want to thank everyone for the comments on the tutorial.
carr52 - that looks pretty nice for your first holster - good and functional - I like it
"Courage brother, do not stumble, though thy path be dark as night: There is a star to guide the humble, trust in God, and do the right. Let the road be dark and dreary and its end far out of sight. Face it bravely, strong or weary. Trust God, and do the right." - General Norman Schwarzkopf
#23 User is offline   carr52 Icon
  • Leatherworker
  • PipPipPip
  • Gender:Male
Posted 15 November 2008 - 12:21 PM
The thanks go to you. With out your tutorial I'd still be hacking away at it. Now I have a great place to start from. I'm hoping my next one will be better. Thanks again Mattsh.
#24 User is offline   MADMAX22 Icon
  • PipPipPipPip
  • View gallery
  • Country:
  • Gender:Male
Posted 23 November 2008 - 06:49 AM
Mattsh I was wondering when you talk of using a wedge to keep the front site channel cleaned out so that it wont catch once your all done what kind of critter did you use for this.
Thanks for the info.
#25 User is offline   mattsh Icon
  • Member
  • PipPip
  • Group: Members
  • Gender:Male
Posted 25 November 2008 - 11:53 PM
Here is a picture of what it will look like. I use a 3/8" dowel and sand it flat to give it a side to sit against the top of the slide as seen in figure A. I then sand the dowel to form a ramp as seen in figure B. Usually the overall length is about the same as the barrel minus the breach, but it is personal preference and what you think will work. The purpose for it is to provide enough room for the front sight to clear the leather without scraping the inside of the holster and getting leather on the sight causing a disruption in sight picture. With the channel being about the same length as the barrel the front sight will be able to clear the holster, since by the time you have drawn your weapon from the holster that distance, your front sight will be in the area of the holster that is wider. This will be where the trigger guard exists and the weapon will have more freedom to move out of the holster and the front sight will be clearing the holster. Hope this makes sense.
http://img.photobucket.com/albums/v41/mattsh/frontsightramp.jpg
#26 User is offline   noob Icon
  • New Member
  • Pip
  • Group: Members
Posted 25 February 2009 - 01:23 AM
great tutorial, how do you get the leather to be form fitted, where you can see the lines of the gun in the leather?
#27 User is offline   mattsh Icon
  • Member
  • PipPip
  • Group: Members
  • Gender:Male
Posted 04 March 2009 - 09:13 AM
noob - to accomplish this you have to 'bone' the leather to the gun.
After you 'case' the leather by putting it in warm water you put your gun or dummy in the holster and press the leather to form around the gun. Then use a smooth tool of some sort to press into the leather the outlines of the gun.
The more 'professional' way to do this is to use a press to fit the leather around the gun. This is done by having two pieces of 40 durometer gum rubber about 12" x 12" x 1.5" and putting steel plates on the outsides and putting the holster inbetween the two pieces of rubber and then 'squishing' it with a press. What this accomplishes is that it compresses the leather which helps with rigidity and also does a decent job at forming the holster to the gun. You would then remove the holster and use a smooth tool to 'bone' the leather to the lines of the gun. This means using the smooth tool to basically draw into the leather the lines of the gun. This helps with retention.
It is personal preference as to how much 'boning' you do. Some makers like to put alot of gun detail onto the leather and others just do a basic outline.
This post has been edited by mattsh: 04 March 2009 - 09:14 AM
#28 User is offline   Tnoisaw Icon
  • Member
  • PipPip
  • Group: Members
  • Gender:Male
  • Interests:God, Country, Family, Guns, Leather, Camping
  • Interested in learning about:Carving
Posted 14 March 2010 - 06:19 PM
Thanks so much for that. I was struggling in my holster design and you simplified it so much.
#29 User is offline   GunNut Icon
  • Member
  • PipPip
  • Group: Members
  • Gender:Male
  • Interests:Guns, Hunting, 4x4ing, Camping, Reading, Video Games.
  • Interested in learning about:Exotic leather and Tooling
  • How did you find leatherworker.net?:Zombie Squad
Posted 08 April 2010 - 09:41 PM
I am new here so please accept my comment with that in mind. I have been making holsters for a few years now and only found this website recently. I felt your tutorial was excellent. It hit on all the points that you don't learn from the patterns you can order. I wish I would have had this when I started. It would have made my life much easier. One thing I do when using an exotic leather with a leather liner is reverse them. I leave the exotic the way you have it but turn the rough side of the leather to the rough side of the exotic. The glue holds much better and you don't have to rough the glue patch. It also leaves a smooth surface for the gun to ride on. I have just recently moved up to a Boss machine from hand stitching so I'm in learning mode again. Thanks for the great article and the pictures!
Gn
#30 User is offline   Billsotx Icon
  • Member
  • PipPip
  • Country:
  • Gender:Male
Posted 08 April 2010 - 10:01 PM
13. This picture shows a couple steps later. Pictures would not have shown much. I have
cut out the elephant and glued it to the flesh side of the cow hide so the smooth side is
inside. I have also cut out the mouth/belt loop support piece and glued it together.
My understanding is that roughside and flesh side are the same. Maybe I'm missing something .... Smooth is grain from what I've read.
This post has been edited by Billsotx: 08 April 2010 - 10:24 PM
Share this topic:
  • (3 Pages)
  • 1
  • 2
  • 3
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
