Sewing Machine Needle Systems Question
  • Please log in to reply
27 replies to this topic
#1 gunfighter48
gunfighter48
    Member
  • PipPip
  • 195 posts
  • Interests:I like making holster for 6 guns and for more modern firearms. I also enjoy making tooled leather belts.
  • Leatherwork Specialty:holsters and belts
Posted 05 February 2008 - 01:46 AM
I have a cylinder bed machine that uses the system 328 needles and it sews my heavy leather just fine. I am thinking about getting a flat bed machine for doing notebook covers, leather pistol and revolver bags with zippered closures, light weight leather items (8 oz down to 3 - 4 oz leather). I have found a number of machines that look like they will do the job and most of them use DPX17, 135 X 17, 16 X 231, DBX1 needle systems. Will the needles these machines use be strong enough to handle 8 oz and smaller veg tanned leather?
Thanks for you advice.
John
gunfighter48
A 45 may not expand but it will never be smaller than .45!!
NRA Member
PSLAC Member
#2 bcurrier
bcurrier
    Member
  • PipPip
  • 212 posts
Posted 05 February 2008 - 09:34 AM
Of the systems listed, DPx17 would be the most suitable at the heavier end, any of the others for the lighter stuff. 135x17 and DBx1 are basically the same and are very common. You want to cast the decision toward where most of the work will be, though, because needle availability in the various leather point types will be a factor. You can get very small leather needles (say 9 or 10) in DBx1, for example, but not in DPx17, where, conversely they are available up to a 23 or so. Personally, I'd get a few needles at both ends of the range I wanted to use first, then sew one of the machines off with some samples using my own threads.
Bill
#3 Art
Art
    Marketplace and Adult Area Moderator & Sewing Machine Expert
  • PipPipPipPip
  • 3,812 posts
  • Gender:Male
  • Interests:Knifemaking, Gunsmithing, Machining, Sharpening
  • Leatherwork Specialty:Gunleather, MC, BDSM & Fetish gear
  • How did you find leatherworker.net?:Johanna
Posted 05 February 2008 - 10:04 AM
DPx17 and 135x17 are essentially the same system, DPx1 and 135x1 are also about the same.
135x17 is a size often used for fabric/canvas etc and usually needle points are for fabric. 135x16 is available in various leather points. 135x16 interchanges with 135x17 but sometimes timing can be different, usually not enough to make a difference so lets say they interchange.
There are many machines out there in 135x17/16 needle systems and they are excellent for the purposes you intended. This system is popular on new as well as older machines.
If you see a 190 needle system, this is what Pfaff uses, like I have said before, nothing fits a Pfaff but Pfaff. This is also a medium duty system and would be excellent for your needs.
I hope this clears things up.
Art
John
#4 Hidemechanic
Hidemechanic
    Member
  • PipPip
  • 333 posts
  • Gender:Male
  • Leatherwork Specialty:custom saddles-restore
Posted 05 February 2008 - 10:11 AM
This isn't exactly what you are going for but I wanted to add that I made a flatbed extention to add to my cylender mechine for doing the kind of projects you are talking about. Though it is still limited at doing fine stiching, it does give me the option to do more jobs on my big stitcher by changing to smaller needle and thread. Comes in handy for other big jobs to like saddle bags, saddle pads, skirts, whatever I want to sew on a flat surface. Cheers,GH
You did What??
#5 Artisan Dave
Artisan Dave
    Artisan Dealer
  • PipPip
  • 40 posts
  • Gender:Male
Posted 05 February 2008 - 11:14 AM
Hey Gunfighter,
Just a small point (excuse the pun) about those needles. Everything I am referring to below follows the Schmetz system of classification.
135 X 17 is a Fabric Point Needle. The system 135 x 16 TRI is the same size needle but the point is for leather. A 135 x 16 TRI has the same Diamond Shaped Point as the 794D system that is used in the Heavier Stitchers like the Toro 3000, etc.
I would suggest you try the 135 x 16 TRI point needles for most of your leather work. For very light leathers, like deerskin, stick with the 135 x 17 as the leather point needles would create too large a hole for proper stitching.
Artisan carries these Schmetz needles in stock - as do many other Industrial Sewing Supply outlets.
I hope this helps.
Dave
#6 bcurrier
bcurrier
    Member
  • PipPip
  • 212 posts
Posted 05 February 2008 - 12:36 PM
DPx17 and 135x17 are essentially the same system ...
You're correct, my error.
Bill
#7 Art
Art
  • PipPipPipPip
  • 3,812 posts
  • Gender:Male
Posted 05 February 2008 - 01:26 PM
Hi Bill,
They're still trying ever so hard to get us (US) to go metric. They've almost done it with size, I still think in Singer and order in metric. Damned foreigners. Artisan has SAE screws in their big machines, but the medium machines (797, 618) are all metric. Course if I had it my way they would be still be using the Whitworth system (remember the MGA and Bugeye Sprite, and the 3000 Healey?).
Art
Bill
#8 wolvenstien
wolvenstien
    Leatherworker
  • PipPipPip
  • 994 posts
  • Gender:Male
  • Leatherwork Specialty:learning
  • Interested in learning about:Motorcycle Stuff, BDSM Stuff, Anything else that interests me
  • How did you find leatherworker.net?:Google search for something or other
Posted 05 February 2008 - 01:31 PM
Damned foreigners or not.... I honestly think we should go metric on everything and loose the SAE system..... one universal measuring system like they intend to do with the universal money....
"The miracle is not how two adults can create a child, the phenomenon is how quickly a child can create two adults." -- VYBE
Her: Hit Me
Him: Do you want me to use the knife?
Her: No, When you hit with a knife, that's STABBING!
#9 bcurrier
bcurrier
    Member
  • PipPip
  • 212 posts
Posted 05 February 2008 - 05:41 PM
... Course if I had it my way they would be still be using the Whitworth system (remember the MGA and Bugeye Sprite, and the 3000 Healey?).
Metric needle size at least makes sense in that it IS a size (nanometers), unlike Singer, which is an arbitrary system and whose numbers look the same as a lot of other sizing schemes. I'm almost there with metric, I just have to force myself to think of the metric size first.
I don't see the needle system issue going away though. I like to reference back to CANU, as it's the closest to a cross-reference available for compatible systems, plus the point designations are consistent. But it still doesn't REALLY cross-reference comprehensively. Take a DBx17 (CANU 37:20) vs. a CANU 38:00, for example.
And yes, unfortunately I am old enough to remember the Whitworth system, including arguments over whose thread specs were better and why!
Bill
#10 gunfighter48
gunfighter48
    Member
  • PipPip
  • 195 posts
Posted 06 February 2008 - 11:13 PM
Thanks guys for all the info, just what I was looking for. I've decided to stay with my heavy stitcher for the present time. If Uncle Sam sends me a $600 check I might think about a lighter weight machine.
John
gunfighter48
NRA Member
PSLAC Member
#11 skipj
skipj
    Member
  • PipPip
  • 259 posts
  • Gender:Male
  • Leatherwork Specialty:cowboy leather
Posted 07 February 2008 - 03:14 PM
What's a needle "system"?
SkipJ
#12 Art
Art
  • PipPipPipPip
  • 3,812 posts
  • Gender:Male
Posted 07 February 2008 - 03:47 PM
Hi Skip,
The needle system defines the two critical dimensions (the diameter of the shank and the distance from butt to eye) and roughly defines the type of blade, including the eye and point. There are about 5 different "systems" from Singer to Canu with additional letters or numbers to designate point types or orientations of the particular system. A few different systems are 135x17, and its "twin" 135x16, 794, 190, 328, 13435, 7x3, and 332 that are used by popular threaded needle machines.
Size is generally the diameter of the needle in any of the above systems. The size is usually specified in Singer or nm or both as in the following:
Singer/Metric (Needle Size Reference table)
S nm
7 55
8 60
9 65
10 70
11 75
12 80
14 90
16 100
18 110
19 120
20 125
21 130
22 140
23 160
24 180
25 200
27 250
Art
SkipJ
#13 bcurrier
bcurrier
    Member
  • PipPip
  • 212 posts
Posted 07 February 2008 - 04:27 PM
A needle system is a set of specifications for a needle. It includes at least shank type and diameter and length from the butt end to the eye, but can also include things such as the specs for the grooves, tapers, flats, etc. The system itself does not specify the point type or size (size is the diameter at the eye end, not the shank or butt end), which are always specified in addition to the system when a needle is ordered, and in fact, there are multiple systems and naming standards for both needle sizing and point types also.
A needle system may IMPLY a size range or point or usage type, however, which only adds to the confusion when trying to figure out if a particular system is usable on your machine. Finally, needle and sewing machine manufacturers have the habit of appending proprietary creative and cryptic bits to existing needle system names when they create a new needle based on an existing type. "794 Serv1" would be an example, where "Serv1" designates a shorter needle of a 794 type ... even though the length would "normally" call for yet another system. Confusing, isn't it?
Needle system naming originates primarily from the sewing machine manufacturers, but many of them are closely associated with needle manufacturers - often because the needle maker was involved in creating the machine(s) with the sewing machine makers from the outset. There are multiple needle system names for most needle types. Although cross references exist - I've seen them - to find identical, comparable, and usable systems, they are very hard to find, and none up-to-date, to my knowledge.
In the end, if you have a machine that takes a common needle, like a DBx1 in a single needle lockstitch machine, you're simply never going to have an issue finding needles in all sizes and points. If you have something slightly more exotic, like the 794 used in the 441 class machines using for sewing leather, it pays to develop a knowledge of systems, point designations, and needle makers.
Briefly, though, there's needle system, size system, point specification system, and various additional proprietary add-on designations. There are multiple systems to specify the system, the size, and the point. It makes for thousands of potential combinations, many, many, many of them for physically identical needles.
It's extremely confusing, but once you've gone through it a few times and understand what you're looking at, it gets better. But then there's THREAD specs ... which are just as bad ...
Bill
#14 esantoro
esantoro
    Leatherworker.net Regular
  • PipPipPipPip
  • 2,259 posts
  • Gender:Male
  • Leatherwork Specialty:briefcases, satchels, handbags, belts, journals
Posted 07 February 2008 - 04:35 PM
I always come up with my own peculiar naming conventions when I'm writing down construction notes for my bags. For example I know that a 42.5" gusset is for an 18x13 gerber , which all means for an 18" by 13" bag with corners made using the lid of a Gerber baby food jar, because it was the right size. If I ever decide to go narrower and use a quarter for a cutting template, it will then be called an 18x13 quarter.
The ideas for naming come to me on the fly. certain names stick and then I stick with them. I've wondered if many industrial naming conventions also came about via such a practical route?
Ed
#15 Art
Art
  • PipPipPipPip
  • 3,812 posts
  • Gender:Male
Posted 07 February 2008 - 05:18 PM
Hi Ed,
It is probably the same thing with needle systems. They mean something to somebody probably long dead.
The system variously designated 7x3, 794, DYx3, and Canu 53:20 are the same basic system and should be called a 2.50x60.00 then add some letters for the other stuff like tip type and orientation.
Then folks say how about all the 2.00 stuff, well there are few diameter x length duplicates there but when there are you could use a 100th of a mm on either side of the true length to fix that, and it wouldn't affect the operation of any machine I know of if they actually manufactured a needle 100th of a mm too long; for instance:
Our old friend the 135x17, DPx17, 2167, SY3355, Canu 37:20 could be called the 2.00x39.00 with a bunch of letter designations for tip and orientation,
and, the infamous TVx3, DVx43, 149x3, 149x31, SY3651, Canu 38:00 could be called the 2.00x39.01 with a bunch of letters.
The DBx1 would end up with a bunch of different systems because the diameter is different on so many of them, but with any good system there are exceptions.
Problem is, there is no agreed upon standards organization and nobody gives a hoot anyway.
Art
Ed
Similar Topics Collapse
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
