secondcrk
Tippmann Aerostitch Ii 975.00
Tippman Aerostitch II For Sale. 975.00obo cash Sews great.Custom Air Filter Setup. Extra bobbins,Needles and Manual. Spare Throat plate. On original stand. Near Denver.You supply the Air (Compressor or air tank 80lbs.) No Trades, No Shipping! E-mail for pics. 303-659-724four Thanks
https://www.facebook.com/pages/Tom-D-Walahoskis-Second-Creek-Saddlery/121621543995?pnref=lhc
It is the strongest Tippmann very heavy duty it's the air powered model used very little.
Tippmann Pneumatic Aerostitch
This is the only machine that can do 3/4 of an inch.
If you only need 1/2 inch there are a number of electric machines that will do. If you need 3/4 of and inch and don't have government budget, this is the ONLY machine that will fit the bill.
Whether you work with materials such as leather (even up to 3/4" thick), canvas, nylon, composites, etc., Aerostitch is the sewing machine to handle the job. Foot pedal operated, the machine can run up to 250+ stitches a minute. Release the pedal, and the machine stops on that very stitch. All this can be mastered by the Speed Control Dial, so you can choose the sewing speed that's most comfortable for you.
Specifications
Make: Tippmann
Model: Aerostitch
Feed Type: Needle Feed/Lower Needle Guide
Stitch Type: Lock Stitch
Bed Type: 3" Cylinder Bed(flat bed optional)
Throat Depth: 11"
Stitch Cycle Rate: Variable 1 to 250+ per minute
Presser Foot Clearance: 7/8"
Maximum Sewable Thickness: 3/4"
Needle System: 794 Series & 7x3
Thread Sizes: 69 to 554
Stitch Adjuster: 4 to 16 per inch and up
Bobbin Winder: Built-in/Manual
Operating Pressure: 80-120 Lb. Air Pressure
Machine Weight with Pedals: 75 Pounds
Edited by secondcrk
Not the only machine that can sew 3/4......
I took that off of Tippmans Manual. I should have read it all! Now I can't Edit it.
Great condition! No reverse. See Pics on Face Book link.
THIS MACHINE IS SOLD! Please remove posting!
