geargarcon
PSA: 1/2 Arbor Press $24.97 @ Harbor Freight
7 posts in this topic
If you can swing the extra money for the $60 1 ton you won't be sorry you did.
Ferg
I want to get an Arbor press to use for snaps and rivets. Problem is all the "easy" modification videos I have seen require a machine shop that I don't have.lol
I did a review on the palmgren .5 ton press here the other day. The machined hole in the ram already fits Tandy dies. You just have to figure out a base plate, which could be made from wood.
Matt,
Check out Gold star tools.  They are out of S. CA.  He sell presses with 1 set of dies for $60 shipped.  Additional die sets vary in price but still inexpensive.  I have two presses my self.  I do find that the dies need fine tuning depending on the snaps you are using.
I bought the 1/2 ton arbor press from Harbor Freight with a 25% coupon and end up costing me just under $19.  I use it right now for hot stamping and it works just great. I personally don see the need for a heavier press as of right now.  You can't beat the price.
I saw on youtube somewhere they did a modification that just required some drilling and not milling or lathe work for the arbor press.  I end up and opted for the Gold Star presses instead.  Anyways just throwing out there what I'm using
Phill
9 minutes ago, 24VOLTS said:
Matt,
Phill
Thanks will check it out.
Where the arbor press really comes into its own is for larger stamps such as 3-d stamps and letters where you need a good amount of pressure.  Hammering on these stamps takes a pretty heavy his using a hammer/mallet/maul and they can bounce leading to multiple imprints.  Not a problem with an arbor press!  - and with some moving around and multiple presses, they can do well with BIG plate stamps.
If the ram is drilled, they can be good for handled tools where you need repetitive impressions along an item - with some other additions such as a platform and guide fence.
For setting rivets & snaps and such the arbor might work but a dedicated machine will work better.  If I had known about the Goldstar at the time, that's probably what I would have bought, but I got the old Tandy version - and it works great, but the dies are terribly expensive.  Thankfully they were on sale from time to time and I bought them that way.
Bill
Create an account
Register a new account
Sign in
Sign In Now
