I just finished these two 1911 holsters. These are 4" and 5" versions of the same pattern. The cant is 25*. They are built using Hermann Oak leather, 1mm Tigre Thread, Fiebing's Pro Oil dyes and finished with Angelus 605 satin finish.
garypl
They look great Bolt!  I especially like the Black and Tan model.
Dwight
Yessir, . . . top notch work.
I am a bit curious though, . . . what weight leather are they?
May God bless,
Dwight
Edited by Dwight
I like it.
The accent appears to be shark, but -- correct me if I'm wrong -- anybody else see the blue elephant in the room ? :whistle:
Straight-up craftsmanship, Bolt...as always...and that ragged piece of "scrap" leather you chose for a back drop was a nice touch as well.
Thanks all.
Dwight - the leather is 8/9 oz.
JLS - you are correct in what you see. Although the elephant color is actually safari grey. But yeah the camera gave it a blue hue.
I love the weight and degree of detail boning.. something about it is just right.
Really nice work.
Looks like from the back shots that you do as I do and run a loop stick through both slots. Some times I also run a thick weight 1.5 in strap through and then pull it around a large been bag I made to help preform to the waist curve.
I use your second option :). I built myself a couple double layer 1.5" wide belt strip samples. One is a full 1/4" thick and the other is a little thinner.
Create an account
Register a new account
Sign in
Sign In Now
