Guest Ehgreen
Not sure what brand made this machine
Guest Ehgreen
Guest Ehgreen
Hi, I've just found this used leather skiving machine, but the seller can't tell what brand the machine is, was wondering if anyone here have seen it before? And how is the machine? Thanks for the help in advance.
What machine is that? I don't see any pictures!. You aren't going to get any help until you post photos of the machine with no name.
Is it hand operated by pulling the leather through a roller in a frame with a 6 or 8 inch wide blade? Or, is it crank or motor operated and pushes the leather against a blade and rollers, away from you? Or, does it have a round spinning sharpened steel cone that skives the leather from left to right under motor power?
Your content will need to be approved by a moderator
You are commenting as a guest. If you have an account, please sign in.
  Only 75 emoticons maximum are allowed.
