MCHS
Finishing over Oil Dye
Hi Members.
Apologies if this has already been asked...
Can I put a water based wax finish over an oil dye?
(Seiwa Wax Coat over Fiebings Pro Dye)
Many thanks
M
As long as the dye is thoroughly dry it will be fine.  Whenever you are not certain, just try on a scrap piece before using on your project!
Gary
Thank you Gary :cheers:
And don't forget to make sure that you have buffed off all of the residual pigments from the Pro Dye, buff until you don't see any color removal on your buffing cloth. If your leather is dry and buffed out your top seal will work every time.
Create an account
Register a new account
Sign in
Sign In Now
