dikman
Carr 369 press and dies
As I mentioned in another post I now have 3 x United-Carr 369 presses. They came with an assortment of dies, none of which fit any of the eyelets, rivets etc that I also got, or any of my existing snaps, rivets etc.The dies are all too big and I have no idea what they're for (see first photo).
I also found a few smaller dies but these are obviously for a different press as they have tapered shanks, but some of them fit the rivets and eyelets! Making adapters to fit the Carr press wouldn't be difficult but the first thing would be to take off the tapers. Easy, just chuck them in the lathe thinks I. Slight problem, they are HARD! After wearing out two carbide cutters I ended up using a belt grinder to take most of it off then chucking them in the lathe and using the grinding belts held against them to make them round. Just have to drill and tap the adapters to hold the dies in place. (Photo 2).
It's also occurred to me to make an adapter to hold an awl blade, then a press could be used to punch stitching holes through very thick welts. I hope.
Another possible use for one of the presses- make an adapter to use the alphabet stamps that came with my stuff. I reckon it should work.
Do the presses run a 3/8" hole?
If so Tandy has a stamp holder set for like 30 bucks that hold all 3 sizes of their stamps.
One of the few things they have that is actually a good deal.
Yep, 3/8". I've already made an adapter to hold the stamps, now it's just a matter of refining the design. One of the presses had been modified by grinding down the "cam" part on one side of the handle and this is perfect for this job as it gives more leverage and pressure on the stamp.
Create an account
Register a new account
Sign in
Sign In Now
