rickmoo
Content Count
64 -
Posts posted by rickmoo
Thanks, i definately wouldn't use a grinder. i would dress it by hand with a file or various grits of paper then polish...the surface i use is and inch or so thick piece of granite, with a sort of hard piece of rubber on it. might be the rubber is the problem. i'll try a piece of wood instead. one would think that with what these tools cost they would be set up right. the arch punches are not new, but the bag punch is..... also a few of the arch punches have a slight flat spot as if had been if dropped. i was trying to think of something tapered i could drive in there it round them out.... any suggestions?
I've been wanting some good arch punches and won a set on ebay. i got a dozen Osborne punches in good shape. i use a 2 lb. plastic coated mallet, but they don't punch veg tan easily. also i paid a lot of $ for a 1 1/4 " Osborne bag punch and i had to dress the inside with a diamond file. the outside is curved inward too much. i bought this to make life easier , more precise and faster, but i'm a little disappointed after paying so much for it. anyone have or know a really good way to dress up these punches to get them to cut properly...
I make patterns from poster board. i use a long metal and short rules for straight lines. i have several templates with ovals and circles for curved parts of patterns... if you have a table saw or band saw, transfer the patterns to either cast acrylic (plexiglass) or 1/4" birch or luann plywood. this will give you permanent patterns and you can hold them in place to cut around... draw or scribe around the template 1st in case it moves while cutting so you can reposition it. also a good investment is a Ridgid table sander that has the belt and oscillating cylindrical attachments. that way you can shape inside curves. i also use them to thin or skive thick leather if needed.
Either www.hidehouse.com they have a great catalog.... or www.leatherhidestore.com
anyone know where to get patterns for motorcycle chaps?
also, the thickness of leather depends on the gun generally. really small guns don't need thick leather. the leather determines to a point what size thread you need. i start at #207 minimum uless i make a holster for say a NAA mini revolver, then # 138 is enough . i use a cobra 4 machine and i have thread from #138 to # 346.
hestes, the threadexchange.com in weaverville n.c. has lots of nylon and poly thread to choose from. all sizes. of course # 207 and smaller there are more colors to choose from, but they have had a good selection in larger sizes too. their site is great and the prices are good also.
Hi there, where do you live in S.C. i live in Charleston and have been doing leather work for a few years.
I thought about that too. i believe you can mold the veg tan with the pigskin a certain amount, but not to the effect of the veg tan by itself. sometimes i use wood shaped like i need for an item where more pressure or hand molding can be used. wetting the veg tan should not penetrate the leather once it's cemented together.
I have a garfish skin in the freezer... been in there for months. would like to know how to tan the thing. was wondrin' if reptan would work.
i'm thinking that you could bind the edge with contact cement, then use several small bulldog or spring loaded clips to help hold it while molding. when i make pen sleeves , i use fabritac glue because it sticks to leather and vinyl well, sets quickly and easy to apply without being messy. i use contact cement for larger projects. buying veg tan type already dyed may not be a bad way to go. hope this helps you.
THREAD WITH A LEFT HAND TWIST IS USED FOR SEWING MACHINES GENERALLY IN THE U.S.
You could get bonded nylon and polyester thread from the www.threadexchange.com Weaverville , N.C. lots of thread at good prices.........
Try boonetrading.com they are in seattle washington
i have to make western saddlebags and i need to know what to sew first. do i sew the gusset to the back panel 1st or the front panel 1st? i'm sewing with a cobra 4 machine.
if you want true shell cordovan, check out www.brettunsvillage.com they had some recently. pretty expensive though.
I've been in the same boat as you. Call me tomorrow and I'll tell ya everything I know and know a few people selling machines if your interested. I will probably post a few of them up here in a couple weeks but if u want first dibs I can get them at a great price
407-406-3477
check out zeussmachines.com
I haven't used the bridle leather, but i've bought many veg tan hides from them in different weights. sometimes they offer veg tan at a great discount. i bought a water buffalo,
embossed ostrich, and embossed gator cowhide from them also. good prices. also water buff belt blanks. that water buff leather is good looking leather.
If you haven't bought a machine yet, check out the leather machine co. i have a cobra 4 and is endorsed by John Bianchi. Cobra Steve will lay on you the BEST customer
service in the business. he sells lots of machines.
Hello, try www.hidehouse.com lots of different leathers. also they have a great catalog. www.glacierwear.com lots of fur hides and deer , elk , etc.
you could get a thick 2" aluminum rule. take a 1/4" strip of wood the size of the rule an glue it to the bottom.that'll give plenty of height to keep the blade at 90 degrees. glad it was
mentioned about the bar stock. i have a 1/4" thick piece about 5" wide and 5' long. plenty of weight so not to move.
I have that pattern also. bought the pattern book many years ago. made a shoulder holster for my bond arms snakeslayer. i modified the pattern a bit. wearing the paper template, it seemed to be tight so i extended the pattern a bit. the straps seemed short, but i used that length. i'm not big and the straps are almost too short. next time i'll ad a couple of inches to the narrow straps. also there needs to be a strap from the bottom of the holster to attach to the belt. i would like to have other shoulder holster patterns, but don't know where to get them.
Hi, i bought a water buffalo hide from www.waterhouseleather.com and it is very nice. 4 oz.. or so in weight it is very flexible and tough. i have the brown color and was only $ 61. i make wrist cuffs with it and made a guitar strap also. i back it with veg tan, glued with contact cement then sewed. it has a beautiful grain and texture. i recommend it highly if you want something unique and get a good hide.
i have a ridgid oscillating sander, but i usually put a sanding drum on a ridgid drill press. drill or cut a hole in a piece of wood 1/4" or 1/2" . let the drum sit down in the hole { clamp the wood on the table } that way the bottom edge of the leather will be sanded also. i like to sand the edge, then burnish with water and canvas. go back and lightly sand again . this way the edge is even and not fuzzy.
Arch Punches And Bag Punches... Sharpening
in Leather Tools
Posted · Report reply
Thanks everyone for your suggestions....
