Content Count
596 -
Posts posted by LeatherLegion
Make sure the motor pulley or the belt doesn't touch he cover
The color is off too. Tokonole is white....yours looks yellowish...maybe it's just the picture though
Under the burnished surface , you still have a "spongy" substrate . If you don't have a high fiber density on the flesh side , you can't really do much about it
Hi Will, Your leather work looks great. Good feedback from existing students will bring you new students.It looks like you put a lot of time and effort to better your skills/craft . Good luck in your endeavor. I just subscribe to your youtube channel.
This is the set of line #24 dies i am using ...
Judging by the firs picture , it looks like you are not pairing the dies /snaps properly
1 hour ago, equineequus said:I'll be sewing wallets, belts, bags. Thread size to be determined because I only hand sew so far.
Mississauga store, being Tandy????
There is one available in Mississisauga store , along with a class 4 , two class 17 and two NP4 skiver
All these machines are on the floor and out of the boxes...I am sure the staff can demo the class 26 for you
Welcome to the board . Interesting and helpful read
Quick Googke search came up with this
I have been using the "S" point exclusively for the longest time in my Cowboy CB4500 and Boss . For anything smaller than #138 thread i am using the LR needles in my Nakajima 341 and Singer 17-30
I have the same press but in green. ...i think i posted some pictures way back. You have to turn the round plate to adjust the height...very fine thread so it's a bit of work , but once you set it and use the same dies , you are good. The press is extremly heavy and has to be bolt it down...i have mine bolted to the floor . I also had a Lucris MA III and the green one seems to have more umph The plate's diameter is arounf 11in . Way better option than one of those hydraulic shop presses in my opinion. If it doesn'y have any cracks and everything moves smooth it'll do the job just fine
Hope this helps
Eddie
Bought a left/center smooth foot set few weeks ago for a 111 type machine. I had to drill a bigger hole in the left foot to make it fit. All good now
Can you please post a more clear picture of the tension discs with the thread ran through?
You need to back stiitch...just cutting the thread and burn the ends is not gonna work. The Jerk (hook)needle does the same stitch as a speedy stitcher or a sewing machine. There is no reason to use a jerk needle on knife sheats or holsters in my opinion
glossy mod pudge, gum trag, and water...nothing beats it. Slick when almost dry
On 2-3oz i usually use an air brush , especially if using an alcohol base dye as i am trying to limit as much as i can the amount of alcohol going into that piece of leather
I can't find those European shoulders on Tandy's web-site , any chance you can post a link?
It looks like Tandy's buckle looks extremely similar at $1.99...but than again , they are not made in the USA like the other suppliers' so i guess the quality is not the same
4 hours ago, Ben00 said:I have called Tandy and they do not supply, neither does spring field leather.
ben N
Is this what you are locking for ?
This one here is very similar
Try the Tan Kote ...it is resin base , not acrylic . Apply it in light coats . It will allow you to apply conditioners down the road if need it
If you are in the "neighborhood" you should drop by...it is worth it . The museum is inside of the store now, very clean and well organized . If you are into leather craving you'll love it ...it is a piece of leather history after all . I am not into carving but still found it interesting
My Italian made leather couch finish is peeling of in 3 spot areas only.
in Leatherwork Conversation
Posted · Report reply
The couch might be actually made out of split leather that has a synthetic finish. I think that's what's peeling off
