StrayDogLamont
Content Count
9 -
Posts posted by StrayDogLamont
I have done quite a bit of research for early 19th Century prosthetics, and have found a few pictures, and that's how I came up with the basic harness design. The pivot of the elbow has apparently been a difficulty for those folks as well. I had found one which used crossed straps which may work, but could cause some rubbing. And there is one with hinges, but like myself, most of our blacksmiths are amateur blacksmiths, and I'm not so sure we could pull off good flat hinges. I'll be talking to them to see what we can do. Thanks for your input.
There are pictures of extant ACW-era prosthetics online. Have you looked at those to see how the prostheses of the period were done?
Getting the blacksmith to make hinges would probably be the way to go. The tangs of those hinges should run nearly the length of the cuff and forearm piece, I imagine. As I said, the concern is that his forearm is quite short, and stability is crucial. I suppose that the best method of attachment for such hinges would be rivets. I do plan to line the cuff and forearm piece with sheep hide (hair inward.) Even though I intend to line the pieces with sheep hide, you're right that under the elbow could pose its own problems.
Thanks again Aaron.
If the strap goes behind the elbow it will pull the cuff off as you are bending it back and forth. It will also rub the elbow raw after a while.
I would suggest having the blacksmith make a hinge out of band iron (long and slender) then you embed it in the leather arm band. I would envision it looking a little bit antique crossed with some steam-punk styling.
The stitches are about 3/8ths of an inch apart (give or take) I could bring them to 1/4 or less, I suppose. How close should they be? I'm here to learn. Thanks Chief.
X2 plus it looks like the stitches are a little too long, a few more stitches per inch and the stitching would look a lot nicer, just my $.02
Thanks Peter. Yes, I drilled the holes, and they could have been smaller for sure. I have a heckuva time getting the needles I have through anything smaller. I suppose the answer is "buy smaller needles!" Thanks again.
It looks to me as if you drilled the holes for the stitches. I don't have a problem with that, but in this case it looks like the holes are quite a bit larger than they needed to be for the thread you used. Tighter fit would help the stitching look better as well as not catching crud in the excess space that is likely to shorten the overall life expectancy of the piece.
Nevertheless, it's a nice piece. Get the stitching tightened up that little bit and you'll be looking really sharp
Thanks Aaron. Yes, a shoulder strap would seem to keep the whole rig in place more securely. I also thought that if the upper cuff were actually connected (as one piece of leather) under the elbow to the forearm, this would cause the forearm portion to tighten if the elbow was bent. Combine this with the shoulder strap, and perhaps were are getting somewhere for a reasonable and practical prosthetic.
Thanks again!
Cool and interesting project. My input is it needs a better hindge on the elbow, you seem to have more of a pivot area. I would also strap the top over to the other shoulder (like a shoulder holster) so it does not simply slide forward and off.
Aaron
You folks are very kind. I am attaching another picture which shows the stitches more clearly. Incidentally, I'm still working on the distressed look - the scars are just a head-start!
I also think it looks pretty good. I think the picture is the only poor quality. I would like to see the stitches a little more clearly. But from what I can tell, your edges look good, your color is even. Now it just needs used a whole bunch to sell that distressed look.
Over all very nice job.
I'm a living historian (F&I War, RevWar, 1812, and 1830's.) I volunteer at an historic village in NJ (blacksmith, militia, and leathershop). I am the only volunteer who has done any leatherwork. We have a new 16 year old volunteer who was born without most of his right forearm. He is currently interpreting the Carpenter Shop, and wants to be able to do more. We thought that it would be nice to try and fabricate a prosthetic arm which would fit in the period (1836) and would have the ability to hold a chisel securely so that this young lad can work - in "period."
The lad's upper arm is a bit more slender than usual, and his forearm terminates about 3 inches from the crease of his elbow. His forearm is tapered/conical in shape, and it is therefore necessary to secure the appendage to some sort of cuff which is attached to the upper arm. At the end of the forearm I have designed what will be a relatively lightweight "hand" that uses a strap-clamp like mechanism to secure a chisel or similar tool. My concern is that even though the hand is not heavy, striking the chisel with a mallet could cause the forearm portion to move out of place. I have attached my preliminary sketch (since this sketch, I have revised the tool-clamping device.)
So, the advice I'm looking for has to do with ensuring the stability of the forearm prosthetic under semi-strenuous conditions.
I would be very grateful for any ideas or advice in this regard. I figured that harness-makers would likely be the most knowledgeable.
Thank you, and may God bless.
I'm a newbie here, but as an introduction, I thought that I'd place my newest leather project up: a half-flap holster for myself. It is made of approximately 9 oz leather. The leather I used already was scarred, so I thought it would be perfect for a distressed look - it's not supposed to look pretty, just functional. The style I chose to simulate was one from around 1879. Generally speaking, aside from the military, flap holsters pretty much ceased to be used by 1890.
I began to do leatherwork when I began making knives - they need sheaths you know. Anyway, I've been doing this for about four years now.
Please, feel free to critique. I am an amateur, and I came to this site for advice and information. Oh, and don't be afraid to hurt my feelings - I served in the Marines (1989-1993).
Thank you for your attention, and may God bless.
Newbie's Holster
in Gun Holsters, Rifle Slings and Knife Sheathes
Posted · Report reply
I use both types of hand sewing depending on the project. I have an awl which I'll use for long lines of stitches, and two curved needles which I use for small/tight areas, or areas which need extra strength. I often groove my stitch lines on the inside, such as where a belt loop will be sewn - knives are sharp. In the case of this holster, the belt loop and the flap-loop have grooved stitch lines on the inside to eliminate the possibility of the pistol breaking the stitches. Thanks for the tips on tools. I really should get some of these things - I've been doing leatherwork without purchasing any leather tools (the awl was a gift). The only specialty tool I have is a slicker, and I made that. The overstitch wheel and 4-prong punch sound like terrific tools I should have. Thanks again for your help.
