cord1974
Content Count
24 -
Posts posted by cord1974
Edge Kote is just that, a costing. It will sit on top of the edge.
My experience with it is that it will eventually flake off.
Dye penetrates the leather and if properly finished, vis pretty permanent.
Can't help with question about lining as I've never used felt. Chamois would be similar to suede, I suspect. I think the contact cement would be fine for it.
On 3/23/2023 at 10:25 AM, Fraulein said:Hi Gosut,
Just a thought about the neatsfoot not darkening your project, I think it depends on the type of leather you are using. I always use imported veg tan and never had any success darkening my projects with oil, so I stick with just dyeing. But I've heard that imported veg won't darken with oil and you have to use hermann oak or something similar to get it to darken with just oil.
~Frau~
Tandy's imported veg tan will darken with NFO.
I use it on almost every project in lieu of dye if I'm trying to achieve a lighter brown color.
I use multiple light coats until the desired color is achieved.
I think it was Aaron from Makers who said Peter Main uses rubbing alcohol as a dye reducer.
I've used it in the past as well denatured alcohol. I can't tell any difference.
On 8/4/2021 at 3:33 PM, Dwight said:I've personally seen a number of their belts . . . that I am convinced were made of leather . . . in the way we make OSB out of wood. Grind it up . . . submerge it in glue . . . and put it in a mold to make the product you want.
American made leather is far superior to that ching chong china crap that's peddled for leather.
May God bless,
Dwight
I've always said "bonded" leather is nothing more than a leather version of presswood.
It doesn't even rise to the level of OSB.
About 25 years ago, back when I was shooting competition heavily, I made a steel lined belt.
2 ply 8/9 oz 1 3/4" Ranger style belt with a thin strip of steel centered. The billets were sewn on the outer strip to avoid the need to punch through the steel. But we did do a double stitch line on the belt.
It worked well for several years of daily wear and weekly matches.
Eventually I got tired of the stiffness and took the steel band out. I unstitched on edge, pulled the steel with pliers and sewed the edge back up by hand.
The belt is still in my closet. Unfortunately I'm not as thin as I was back then.
On 4/11/2021 at 7:35 PM, JamesCB said:I have made a leather holster for my S&W .38. Dyed it black and buffed with shoe polish. The black comes off on my hands. What can I finish it with ?
With black you really have to buff it well.
Start with a soft cloth or wool. Buff it. Buff it again. The buff it some more. When you think you're done, take a soft paper towel and buff it. If any dye pigment comes off, start over.
After buffing seal with your sealant of choice.
I've been noticing Tandy is carrying less and less of a selection in Pro Dye in quart bottles.
I've been to two larger stores (Jacksonville FL and Tampa FL in the last several weeks) and only found a few shades of brown available.
I would guess they're phasing out a lot of the Fiebings dyes in favor of their Eco dyes.
I recently did a few belts this way.
After stamping I resisted using Wyosheen. After that dried I mixed a bit of dye with the Wyosheen (I read about that trick in one of Stohlman's books) and carefully used a small paint brush to go around each letter.
After I'd gotten enough distance from the letters I dyed as usual.
20 hours ago, DavidRM said:It reminded me of Resolene. I like it a little better than Resolene as I find Resolene bubbles or streaks too easily and works best if sprayed.
That was my thought as well.
I do like Resolene. And I'll end up using both eventually.
Between Leather Balm, Resolene, Gan Kote, "Neat Lax" and Wyosheen I have all my finishing needs covered.
I haven't ordered from him yet but I've read nothing but great reviews about him and his business.
Edit:
Springfield says Clear Lac has been discontinued.
Ordered through Barry King!
2 hours ago, darkmatter35 said:Barry King sells Wyo sheen
Springfield is vary helpful if you call them
John
Thanks!
3 hours ago, NVLeatherWorx said:I found ClearLac and found out that it is the original Neat-Lac I jumped on it and haven't looked back. I love that stuff; great finish and the finest resist.
I'm on Springfield's page now and can't seem to find it.
Any suggestions?
I know Springfield has the "old faithful".
I guess I need to go ahead and order some. I was just very disappointed.
I was in a Tandy store a month or so ago. Hadn't been in about a year.
I got all excited because they had brought back "Neat Lac". Has anyone else used this yet?
Because unless I'm losing my marbles I don't think this is the same as the old Neat Lac they used to carry.
Old Neat Lac was thicker and had a much different smell. The new product is thin like Resolene and behaves and smells very similar.
Anyway, just wanted to see if anyone has had a similar experience.
Sorry to drag a thread back from the dead but...
If I'm doing something that will be worn I generally don't dye the flesh side. I do coat it with a finish though.
My personal method: tool or stamp then one light coat of neatsfoot. Dry at least overnight. Sometimes as little as 8 or up to 16 hours. Then a second coat if antiquing. If not then dye.
That again dries at least 8 hours then buffed and coated.
Used it before to glue holsters. Great for a lot of stuff.
Yin, if you're carving and tooling a lot, then no. You're doing fine.
I just don't have the time to do as much tooling as I'd like.
As someone said glycerin is available at any drug store. I bought a four ounce bottle 10 years ago and still have plenty..
Thanks Yin.
It was Bruce's recipe I used but couldn't remember what it entailed.
I mixed up a quart bottle a year and a half ago and I'm still on the same bottle..
Somewhere on here is a recipe for a casing solution.
I forget who posted it but remember it contains Lexol and something else.
I experimented with it and did see an improvement in the burnishing effect the tooling took one.
On 12/15/2017 at 10:44 PM, Mjolnir said:have you ever cut your own hair? I don't recommend it. When things go awry you think to yourself, 'maybe if I just shave a little to the left'. Next thing you are bald. if you think you can pull of bald, ie scrap your nice work. keep shaving. A maker will see every flaw in his own creations magnified a thousand times. A True Persian rug always has one knot tied wrong.
I think your wife will love it. nicely done.
I go through this with every single piece I make.
Something, anything, makes me think, "it's ruined". Yet, when the person it's made for receives it they never see the flaws I see.
Someone told me that's being a true artist, always striving to make the next piece better than the last.
On 8/3/2011 at 2:34 AM, Ladykahu said:Are there different base types (oil vs water) to the buffing compounds? or could it just have been his block was to old and had dried to much to rub off?
What I do for any strip is to take a bar of green compound and scrape off flakes into a cup.
Then I grind them as fine as possible. Add a bit of mineral oil til I have a slurry paste.
Then I run this into the leather.
It's worked well for the last decade.
I'll check what I have. If I have it, it's yours. May take a few days. I'm out of town til the weekend.
alternative to pro dye for Californians
in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
Posted · Report reply
I'm seeing less and less Fiebings on Tandy shelves every time I make the trip to the nearest store.
They seem to phasing it out Fiebings products favor of the Tandy Eco equivalent.
