Posts posted by David
I don't mean to rag on your seat, its very nicely done, but, I've never seen a seat done that way.....The graphic and lettering are upside down from the usual way of doing things.
Dave Theobald
one word of advice, if your making motorcycle seats, you don't want to dye your seats black. It rubs off and your customer will be walking around with a black butt. They won't be happy! There is NOTHING that will prevent the rub off, trust me on this one guys, lots of guys say they can prevent it with satin sheen, or super sheen. Well as soon as that sheen rubs off the black will rub off also. AVOID BLACK DYE.
Any black seats that I do I use factory dyed black leather with no tooling.....
Dave Theobald
The edge braiding is two color Mexican braid. Thanks everyone for the kind words.
Your art work and airbrush work is impecable. I doubt its longevity. I'd like to see one of these seats after a season of heavy riding..
Good looking seat though, I just think its a show bike seat.
One question, have you done a black seat with white paint on it before?
I always hated doing "read-a-seats" had a customer that wanted an entire 35 word verse plus a gothic cross, with flowing banner and roses...... I told him I would put the name of the Chapter and the numbers of the verse. He didn't want that. I try to limit my writing to 3 words...... Just works out better that way.
I declined the job. He had another leatherworker do it. The guy used Tandy letter stamps......oh man it looked like .....well you know. So happy I never had to put my name on that one.
I guess I'm just a bit weird, I love to lace…..The bicolor stuff looks complicated but once you get started its not bad. Just takes time.
And it doesn't take a huge amount of time to pick up the basics, again its just time and repetition.
I was fortunate, I made my first seat and the right guy saw it……then I made about 300 seats for them in a 2-3 year span.
So, now doing a seat is like …. falling down… its easy to do….
Thanks for the nice comments.
Dave
There are several Tandy Craftool stamps with that texture.
A889
A888
A888-2
Just finished my first seat in a while. I wanted to try lacing with brass grommets in both sides. I also wanted to try heavier leather. This seat is all 11-12 oz. leather. I normally use 8-9 oz. leather
All in all, I think it turned out ok. I liked tooling the heavier leather of course. But lacing with grommets.....it may be quite a while before I do that again. The two color lacing was a lot of fun. I like the look of it, but it is time consuming.
Dave Theobald
Anyone have info on this show?
No idea what they are for, but they sure demonstrate incredible craftsmanship.
Thanks for sharing.
David Theobald
Beautiful work, that hand stitching is amazing. I like the tooling just as it is.
Dave
High density neoprene from Foam and More
do internet search for them.
Dave
Nice paint work on the bibs.
Dave
Nicely done!
Shadowryder,
I've made a few solo seats. Maybe I can offer some advice. Your leather is way too thin. I finally hit on 8-9 oz. as being the best for a solo seat when you use the construction method you use. (It's the same way I build seats.) Lace, use the best! That would be kangaroo lace. I used 1/4" lace and 1/8" holes. The bad part is it is expensive! Regarding the holes, mine are 1/8" holes 3/8" apart (on center) and set in 3/8" from the edge. The holes must line up, and remember the top and bottom leathers are neither the same size or shape if you use 3/4" padding like I did. So line them up carefully. There are several posts on here about how to do it. When you finish lacing, tap your lace with a mallet. It will make it lay down flat and look more consistent. Make sure your splices and endings are invisible. No one should be able to tell where you start or stop.
Regarding seat expense, mine cost me $320 to make so be sure you charge enough! I bought my pans so that added $60 to materials cost.
Keep building, it will come!
Very nicely done belt. Thanks for sharing it with us.....I agree about black
Dave
I'd love to see it, but the link takes me to a page about carved cow horns. I just noticed how old the post is, Probably out of date.
Dave Theobald
Tony,
My advice is to learn to build a traditional saddle, then start making modifications. By the time you have mastered saddle construction, I would wager that your antler idea will be the last item on your "to do" list. By the way, a saddle for your first project....not a good idea.
Dave Theobald
The foam goes on first then rivet the back.Dave, first thanks for a great tutorial, I've always admired your work. I do have a couple of clarification questions if you don't mind.
1.I understand your brief explanation about the steps outlined above but in the pictures earlier in the post you show the foam being mounted to the seat prior to the back being riveted, do you rivet the back piece first and then glue and trim the foam or vice versa? The text says one thing but the pictures and explaination shows a different process.
2. I've made my bottom pattern with tape as described and added 3/8" onto it, on the top though does your pattern only go to the edge of the top bevel and then get 3/8" added or does the pattern get created from the top prior to the beveling of the foam. I made my top pattern to the edge of the bevel and added 3/8" but it seems that it will be to small for the number of holes that the bottom piece has and as such will not match. Using about 1/4" spacing b/t holes I get 74 holes on each 1/2 of the bottom piece and with the difference in size between the top I cannot get that many on the top pattern without some running together, So my thought was that I was cutting the top pattern to small, but it matched the bevels which aren't that large. The only other difference is that I'm using 1" foam instead of 3/4" but that shouldn't affect the hole spacing..
Does this make sense? Any advice would be appreciated.
What size holes are you using? I use 1/8" holes for the 1/4" lace. My seats had 100 holes around a seat that had a 36" circumference.
My solo seats are all 7-8 oz. front and back. All of my seats are 2 piece. For a frame mounted seat 7-8 for the top and 3-4 for the sides which are pulled around and riveted to the back. Again check out the posts by Roger for frame mounted seats. The Christian bike seat was my how-to for spring mounted solo seats.
Very nicely done. It looks like you used some sort of gloss finish on the black. Be careful doing this, a bit too much gloss and you may find the finish cracking. If the finish cracks it will begin to peal off. My advice would be to apply your gloss with a lint free rag in thin coats and rub it in. I understand the need for something over the black dye because the black WILL rub off. The gloss will prevent that for a while at least. However as soon as you wear off the gloss, the black will begin to rub off also.
Motorcycle seat finnish?
in Motorcycles and Biker Gear
Posted · Edited by David
You can see my seats at www.theobaldleather.com
I use only Fiebings spirit dye applied with an airbrush. Followed by Fiebings antiquing paste. When dry for 2-3 days I use Fiebings Leather Balm with atom wax. Buff when dry.
