Content Count
166 -
Posts posted by panchoskywalker
These are pictures from the web. Both leather looks wrinkled giving that vintage look.
Thank you, the other option I have is to cut the actual leather just before the bend and add new leather over it. Because the bond between the leather and the foam is pretty strong and replacing the foam? I would not know how to do that as it has a shape.
9 hours ago, Klara said:Two possibilities: Try airing the watch band for a while (outside of direct sunlight). You could also put it in baking soda (if you can get it cheaply) or alum.
Regarding edge paint in general, do you absolutely need it? Do you use any other dyes? You could try dyeing the edge (possibly with vinegaroon, that doesn't smell good either, but once dry it's okay) and waxing it.
I've sand all the edge paint out but the smell is still there, I can try the baking soda thing, for how long do you suggest to leave it?
18 minutes ago, MtlBiker said:What type of edge paint was it? And the brand?
I live in Chile and bought it locally, it is made here and sold as "color shoes" brand. I am pretty sure it is not exported.
12 minutes ago, Tugadude said:All chemical materials have an expiration date. I have some Fiebing's Edge Paint that smells terrible in the bottle, but after it is applied, the odor seems to dissipate. I actually have two, one black, one brown and only one smells bad.
As someone who has had a career of selling chemicals, and products comprised of various chemicals, I do not find it unusual that some products develop bad odors over time. Many products, especially water-based, can harbor biologic growth, i.e., mold, mildew, fungus, algae, etc., etc. which can smell ripe. Some products have inhibitors added to stem the grown of biologics, but many don't, and they don't work forever either.
If I were you, I'd purchase the smallest practical size of paint and understand that it will indeed "go bad" at some point.
I am thinking about sanding it and redo it with a new bottle as it smell so bad I doubt it will go away.
The smallest bottle available locally is 250ml and it cost US$4,5. It is pretty cheap but I will only use it once in while, and as it expired, I might spend a bit more for smaller quantity as it will probably end up in the trash can. Just thinking.
Hello, I applied edge paint on a leather watch band I made and it smells really bad. I did not know these things had a expiry date.
Will the smell go away or not?
17 minutes ago, TomE said:A classic. Very nice work. Do you trim the edge of the round handles after sewing? How do you get that close to the edge?
Now I see that it is hand sewn. Lots of work!
Thank you.
I did not trim the edge of the handles. I did a test first with small piece of leather. The rope is 1cm diameter, the leather was 5cm wide and I did the holes before putting everything together like in this video.
24 minutes ago, dikman said:Great job! That is a lot of hand-stitching!!
Thank you. I had to make a break a few times because of the pain on my fingers.
Hello, I wanted to share this weekender bag I just finished. I already made one like 5 years ago and I decided to do another one as I had this beautiful green canvas I did not know what to do with. I hope you like it. Everything was stitch by hand, except the lining.
Sorry for the background on the picture, my model was on holiday so I had to improvise.
Hello, I went out of thread in the middle of a weekender bag. I was using wuta polyester thread, dark brown so I went on ali and boght a new spool but apparently they since changed their color set and the one I bought is darker than the original.
This is the one I had
But now the wuta thread looks like this:
And this is the dark brown on my bag.
I now bought a new one which is called caramel which is at the bottom next to saddle brown. Hopefully it is at least closer.
14 minutes ago, Hags said:No idea, but very interested in what they are worth. Could we get more pics of the other stuff?
Maybe, I am waiting for response from seller.
8 hours ago, Dwight said:No . . . you do not fasten my bottom piece to the bag. It is a friction fit . . . that way if something leaks or spills out . . . just run a finger under it and pull it out.
I'm not sure I've ever known a woman who at one time or another did not have something spill in their purse or tote bag.
Plus you can just lift it up on one side and the bag will then fold flat fairly easily for storage.
May God bless,
Dwight
I see, very interesting. I'll think about this option.
Thank you very much.
Both ideas are good, how do you glue the lining to the bottom? Applying spray glue?
I used a special cardboard called lefa cardboard glued at the bottom of the bag but it's glued to the outer skin as you say. My problem is with the lining, how to make the bottom of the lining heavy enough so it stay at the bottom.
Here's the first bag I did, I want to follow the same pattern except for the lining.
Hello,
I am planning to do a weekender bag with fabric and leather, I already did one a few years ago but I am not 100% happy with it and I found a nicer fabric. This time I also want to improve the lining as the one I did is baggy at the bottom of the bag, so I was looking at this video as an example but it not 100% clear,maybe you can help me to understand.
She make like a 3 pieces construction. The bottom and each side. The bottom is a rectangle with a doble layer of fabric and these layers are just glue together, is that right?
1 hour ago, fredk said:In the ebay listing both the label and the seller says its made from horse hide
No, its meant to be a bear. Close-up of the label on ebay - see link by OP
Where can I buy horse hide? There are just a few listing on ebay. Is Upholstery leather ok for a jacket?
First soccer ball
in Show Off!!
Posted · Report reply
Thank you!
Thank you!
Thank you! The most difficult part is definitely the closing which is the last thing, I watch a lot of videos on YT before doing it. I won't use, I just made it for the challenge.
