stampingdelight
Content Count
78 -
Posts posted by stampingdelight
40 minutes ago, Northmount said:It is the reaction between iron and tannin, same as used to make vinegaroon if you would like to look that up.
Keep all iron filings off your work space!
You may be able to bleach it out using oxalic acid (teaspoon full in a pint of water) or wood bleach, or barkeeps friend (which all contain oxalic acid. Rinse after to reduce the acid left in the leather.
k did not even know had iron on my work space. will looking into the bleaching have to look to see what item is in store
1 hour ago, AlZilla said:Missed this part. I kept forming the hat into the shape I wanted as it dried . Just kept coming back to it. Once it was dried, it stiffened up and has held it's shape, except for that pesky brim. I hit the inside with Leather N Rich, too.
thanks & you did just the brim on the inside or underside with the leather n rich
5 hours ago, AlZilla said:So, I wore my hat out in the rain today and meant to grab a picture of how well the water beads up. I waited too long but there's 1 big blob left on the right side. I was inside maybe 7 or 8 minutes. I looked at it when I first walked in and it was beaded all up with rain. I probably haven't hit it with anything for close to a year.
thanks letting me see just hopping can do & not have to keep putting on not sure of one needs to do it every few months or if once on is good to go thanks again for the help
On 4/23/2024 at 7:54 PM, fredk said:Try rubbing in vaseline
should I do when full try or damp & what does vaseline do to the leather never tried
looking great
11 hours ago, AlZilla said:Blackrocks Leather N' Rich has worked on mine for a couple of years now. Been rained on a few times and wipes/dries right off.
k thanks will check it out
12 hours ago, DieselTech said:Nice work. That's awesome. I have been wanting to make a leather hat like that. I would also like to put some type of wire around the brim of it so I can form/ bend it in any shape I want.
Great work.
like the idea of making the brim bend to any shape. are you looking at using leather or something like felt for the brim?
1 hour ago, AlZilla said:Outstanding and congratulations. It's a tough project, isn't it? The hat in my pic was the first bigger project I did. I made a rookie mistake by getting into the belly for my brim. I constantly have to flatten it back out.
Looks like a 1 piece crown? I used 2 pieces, sewn front and back. Then I made another with a 1 piece crown and it just doesn't sit right. Never came back to it.
How about a pic of the inside?
what part is the belly of the brim would that just be the middle & what did you find worked best to help keep the water from changing shape of the leather? thank you & yes a tough project. yes 1 piece crown thought would be easier for me. one you made looks nice, hope mine comes out nice looking once dyed. I see some speak of cleaning leather before dying is that something I should do, if so what should I use?
10 hours ago, Dwight said:very nice
how cool will have to try at some point
30 minutes ago, Northmount said:Moved out of Help wanted to Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
Posts in Help wanted need moderator's approval before they can be seen. You are better off asking questions here.
k thanks so just ask leather work questions in these topic area
what does everyone recommend using on a leather hat to help keep water proof & does not change the shape if some items can do that.
what is diffrance between leather polish leather conditioner or leather cream & what do they do
checking if anyone has the facehugger tail pattern
has anyone used premium acrylic paint on leather, how does do on leather?
I am double checking when painting or dying a leather mask that will have wet molding do I paint or dye before or after I wet mold? was thinking after just seeing if might be doing wrong
thank you my first rose & 4oz I think not seeing the tag now
On 12/7/2022 at 9:28 PM, Bert03241 said:thats cool who's going to wear it?
I will unless friends want to wear
I wanted to share a crown I made with leather & antlers but, not sure where to post photo of it or if can share in the site. Not sure how much leather something has to be over other items used & such.
leather hat
in Show Off!!
Posted · Report reply
k thanks still learning so was not sure if belly could be name used for part of the hat, happy you said is belly part of the hide. did the curling of the brim come more from using the belly or did you do something to give more that look thought might try when do another hat. is binding hard to do on a hat would that be just wrapping it in leather & making the hat have a trim around the edge? thanks again for all the help
like the idea
