07milch
Content Count
29 -
Posts posted by 07milch
I got the 160 needle in but unfortunately it made no difference. Still hunting for the solution.
3 hours ago, Wizcrafts said:I have better success using #23 (160) needles with #138 thread.
Ok! There was a chart somewhere, can’t find it at the moment, that said this machine could only use 120-140 needles. I’ll see if I can find a 160 and try that.
2 hours ago, Wizcrafts said:If we make the assumption that the machine is properly threaded, the tension problem could simply be too small of a needle for the thread combinations. Consult this needle and thread chart and use the largest needle recommendations in dense leather.
Thank you I am using the largest one the machine can take. I think it is an adjustment issue.
I have a new to me Adler 267-373, and let me preface this question with the fact that I know next to nothing about sewing machines.) I’ve looked at numerous diagrams and pictures online and I’m fairly confident that I have the machine threaded right. I cannot seem to get my stitch knot to sink into the leather. I have a very minor grasp as to how to adjust tension, but have not seen any change in the stitches when I do make adjustments. Also, when making these adjustments, my thread wants to get jammed up and then throws my timing off, forcing me to constantly reset it. It says my pictuare too large to upload but I’ll keep playing with that.
7 hours ago, Wizcrafts said:The 105-64 will be useful to you as long as you are sewing at least 1/8 inch of material with #138 or larger thread, using a #22 or larger needle. Also, your projects will have tooth marks on the bottom. If your jobs meet these minimums, the Adler may be a good investment (as long as it doesn't need expensive replacement parts).
Thank you!
5 hours ago, Constabulary said:The 105-64 is a bottom feed + needle feed machine - they usually have less aggressive feed dogs compared with plain bottom feed / drop feed machines. So the marking are approx the same as on walking toot / triple feed machines.
Thank you for the additional info, that helps!
1 hour ago, Wizcrafts said:This machine has been discussed on Leatherworker.net. Use your favorite search engine to search for this term:
site: leatherworker.net adler 105-64
Thank you but I’ve already read every thread on here regarding the machine. There actually isn’t very much info.
Anyone else have feedback on the 105?? Or any other suggestions on machines to look into? What about the Cobra 26?
12 hours ago, jimi said:Although the 105-64 is a nice med-heavy duty needle feed machine, i think you would be better off looking for an Adler 69 or Pfaff 335 type machine. I am sure there are other options from other makes for this class of machine also. I personally use a Pfaff 335 for wallets,purses etc.... On the other hand if you were planning on doing belts and heavy stuff which needs a bigger needle and thicker thread, then the 105 is a very good choice. hope this helps.
Thanks for the feedback! I'll check into them
I’ve been researching machines (first time buyer) and am utterly overwhelmed. I mainly do purses (total of 6-12 oz) and other small goods. I was told an Adler 105 would be good? I found a nice 105-64 near(ish) (5 hrs away). Would this be a good machine?
10 hours ago, valafar said:Hello
I make bags like these I think the wear depends on the way its used and your design I try to add leather accents or straps that might take some of the wear but if its a great bag and the customer loves it they will buy another just disclose that this could happen and its not a defect but something that can happen with wear.
I you would like to see the construction I am located in Washington state your welcome to come by the shop also you can see some bags on my facebook
Have fun making the Bags !!
Greg Allan Saddlery llc
Just found you on FB and Instagram! Your bags are super nice, and thank you for the advice. I think I’ll take your suggestion and just warn a buyer beforehand that this might not be an “every day” kind of bag and tell them how to care for it. I’d love to come by your shop sometime, I’ll have to plan a trip to your side of the state! Chelsea
Question. Has anyone made a purse completely out of hair on cowhide? I was told that the hair will rub off where it rubs against my hip. And I know this did happen to a friend of mine. So does it happen to every purse or was that a fluke?
This tutorial was super, super helpful. I'm curious as to what size and brand of tools you use on the tooling? Thanks!
On 5/3/2017 at 0:34 AM, Leatherhips said:Dependent on the effect you are aiming at you might want to look at the Beetroot Tiger thread.
I was going to say this too.
I'm wondering this too!
Thank you for sharing!
Timing issues Adler 267 flat bed machine
in Leather Sewing Machines
Posted · Report reply
Could you send me the info too? I have a 267 that I need to take to a good repair shop.
