1960plumber
Content Count
12 -
Posts posted by 1960plumber
3 hours ago, MtlBiker said:Please confirm that to back stitch, you are actually turning the wheel in the opposite direction. That's what I understand you to be doing from what you've written. If that's really what you are doing, why are you not using the reverse lever? The wheel should ONLY be turned in the normal (towards you) direction. I hope I've misunderstood you. (Don't forget that I'm a novice, much like you, so I may be way off.)
Yes, I'm using my reverse lever.
10 hours ago, MtlBiker said:I'm just a novice myself but what you said above caught my eye... As far as I know, you should never turn the wheel backwards. Only forward. Turning it backwards can cause lots of problems, including thread jams/nests.
Thanks I only do it at the start and end. I only been back stitching 2 threads and it seem to be working ok.
18 hours ago, Wizcrafts said:Is it the bobbin thread or the top thread that is getting tangled? Post a picture of the tangle to help us diagnose the possible cause.
I think your right it's the top thread. Is this still a tension problem?
Some times in reverse the bobbin get tangle up. Would this be the tension on the bobbin
I thank you all I got it a working.
#1- Had everything threaded right but at the needle.
# 2- Didn't have needle all the way in. -
When I put it all the way up, then the hole for my thread is block. And Thanks for your help.
When you take the needle out, how do you know when you have it in the right place.
Yes I'm holding the thread. Does the thread come out of the top of the bobbin in the little groves or the side? I'm not picking up my bobbin thread. An it looks to be in time.
It keeps tangle up on the hook.
Have a few question on the bobbin on the Juki 1341.
I can't get the thread to come up with the needle.
With the bobbin out I can turn the wheel by hand in forward direction and back, but with bobbin it will it will only go forward. -
Wow, I never thought it would be so hard to buy a sewing machine. I will only be doing wallets and bags on it will be here in 2 weeks..
Juki LS1341
in Leather Sewing Machines
Posted · Report reply
Can anybody tell me if the Singer 111w feet fit the Juki ls1341.
