JohnInAZ
  • Content Count
    5
Posts posted by JohnInAZ
  1. 6 minutes ago, Wizcrafts said:
    Several years ago, I tried sewing 8 ounces of chrome tan (4-5 oz) lined with suede (3oz), with #138 thread and a #23 needle, at different speeds and found that the needle started smoking at about 9 stitches per second. Above that the smoking got worse and the thread eventually melted or shredded.
    As I read your comment, I was thinking, wow, 9 stitches per second is screaming fast.  Then I did a little math and realized 2200 SPM is over 36 stitches per second!
    I think some of my back tack problems might be caused by the needle size.  I'm using a #22, which is a little borderline for 138 thread.  Last time I went to buy needles, I couldn't find anything larger than a #22 in a 135 x 16 size.
  2. I thought I would add that it appears to be a high quality machine.  Mine was made in Japan, and it shows.  The manual says that it is for "medium thick to very thick" materials, although says nothing about leather.  As Wizcrafts said, it is designed for high speed sewing, 2200 SPM.  When I bought it, it was so fast it was scary.  First addition was a servo motor to replace the clutch motor.  That helped a lot, but I still added a reduction pulley.  It's much slower now, but I still feel it's too fast for leather.
  3. This is an old thread, but I have an LS2-F52A, so I thought I would comment.  I bought it new around 1996, for sewing marine projects (hobby, not as a business).  In the last couple of months, I started playing around in the leather craft world.  I've been trying to use 138 thread top and bottom.  It's not working well.  I can get the tension adjusted so it sews nicely when going forward.  However, a back tack is pretty ugly on the bottom.
    One problem I noticed was that it would sometimes "short stitch" when going forward from a back tack.  Focusing totally on the movement of the leather, I saw that the leather moved a little backwards as it made a stitch.  Thinking about it, the only part that moves backwards (other than the needle when it's out of the leather) is the feed dog.  This only happens for the first few stitches after a tack tack.  I began to wonder if the feed dog was catching on the jumbled stitches from the back tack.  So, I lowered the feed dog height slightly, and the problem went away.  HOWEVER, it's now somewhat finicky when removing the bobbin, because the feed dog linkage interferes.  You have to go about an inch past the hand wheel alignment mark, and then fiddle and wiggle to insert or remove the bobbin.   I'm beginning to think this really isn't an optimal machine for leather craft.  Maybe thin garment or upholstery, but not for what I would consider "leather craft".
  4. On 4/14/2021 at 2:15 PM, Lokahi said:
    I don't have any 92 weight thread to switch to.  I can try with some 69.
    I'll try to attach some pictures.  If my code doesn't work, they're here at this imgur post: Threading Consew 206rb
    <img src="https://i.imgur.com/coCdPcQ.jpg" alt="206rb thread post" width="4032" height="1908">
    <img src="https://i.imgur.com/g5MGTLS.jpg" alt="206rb top thread guid" width="4032" height="1908">
    <img src="https://i.imgur.com/GfHqnaY.jpg" alt="206rb tension discs" width="1908" height="4032">
    <img src="https://i.imgur.com/N4OKDko.jpg" alt="206rb take up lever" width="1908" height="4032">
    <img src="https://i.imgur.com/VhL7dyM.jpg" alt="206rb lower thread guides" width="1908" height="4032">
    <img src="https://i.imgur.com/50PdlFN.jpg" alt="206rb needle threading" width="4032" height="1908">
    Ok, I had a paragraph about what I thought was a threading problem.  Well, as soon as I clicked "Submit" and looked at your pictures again, I realized the only problem is with my eye sight.  Nice first post of mine...
