GavinO Report post Posted March 25 Hi all, I have had my Adler for about 4 years with absolutely no problems. However, I think I pushed it past its limit of thickness it can sew a couple of weeks ago and it threw the timing off. The repair main fixed it but it happened twice thereafter and he has now given up. I made the layers I was sewing much slimmer and managed a good few days of sewing but it just went again. This time though, it was during an operation it absolutely could do before the problems started- reasonably thick layers and zipper, perhaps the needle hit the metal of the zip and that threw it out. I have another repair guy coming tomorrow, I am worried the damage I have done has now made the machine more delicate than it was. I will talk to the repair guy about it but I wondered if anyone had any experiene with this, or tips. It is getting expensive to have repeat repair man visits, so is there a way for me to get a more permanent fix? Or is it a relatively easy thing for me to fix if it happens again so I can just manage it myself as and when it happens? I am fairly uncomfortable getting into the mechanics of my machines because I don't feel like I know enough, but if it is a matter of a slight re-arranngement and tightening then maybe it is time for me to learn. Quote Share this post Link to post Share on other sites
Michiel Report post Posted March 27 Timing a sewing machine is no magic. i would suggest you read about it on internet and / or watch videos about it (no matter what kind of sewing machine, just to understand whats going on) than dowload a service manual for your machine and follow (all) the steps in it first time it can take some time to figure out where the screws are located but after a few times you even do not need an manual to time an unknown machine if you cannot find your service manual on internet you can sent me a dm kind regards, michiel Quote Share this post Link to post Share on other sites
GavinO Report post Posted March 27 12 hours ago, Michiel said: Timing a sewing machine is no magic. i would suggest you read about it on internet and / or watch videos about it (no matter what kind of sewing machine, just to understand whats going on) than dowload a service manual for your machine and follow (all) the steps in it first time it can take some time to figure out where the screws are located but after a few times you even do not need an manual to time an unknown machine if you cannot find your service manual on internet you can sent me a dm kind regards, michiel Thank you Michiel, your advice is well appreciated. I was kind of getting to this conclusion but opening up machines just makes me nervous. It is fixed for now and the repairman was very re-assuring so hopefully it is sorted for a while Quote Share this post Link to post Share on other sites
Michiel Report post Posted March 27 1 hour ago, GavinO said: but opening up machines just makes me nervous. I can imagine when i started I bought an old (not very expensive) sewing machine to see if i could fix it before trying it on more expensive machines Quote Share this post Link to post Share on other sites
Marcremb Report post Posted March 27 Hello Gavino Their is a Duerkopp Adler 69-373 Service Instructions Manual Direct link: https://www.manualslib.com/manual/461563/Duerkopp-Adler-Duerkopp-Adler-69-373-Service-Instructions-Manual.html Page 19 hook setting (timing) And here is a very well made video as usuall from Uwe about a Adler flat bed sewing machine(horizontal hook) . I know yours is a cylinder bed (vertical hook) but Just to learn the principles of timing a hook to needle Also this man Mtrc crane (YouTube name). He does maintenance on a Consew 206 flat bed that as a vertical hook. Just look at the first 20 seconds and jump to 45:24 for the timing needle to the hook. Hope it Will give you self-confidence for fixing your machine in futur needs. Wrong copy This one : Quote Share this post Link to post Share on other sites
GavinO Report post Posted March 28 (edited) 20 hours ago, Michiel said: I can imagine when i started I bought an old (not very expensive) sewing machine to see if i could fix it before trying it on more expensive machines Good idea! I have moved to Canada from Europe, my other machine is a domestic Bernina 1130 from the 80s (I use for linings/other projects or very light leather work)- it is hard to get people who are willing to repair it when needed. Would be good to be a bit more self sufficient Macremb- thanks so much for this info, super detailed and useful! Edited March 28 by GavinO Quote Share this post Link to post Share on other sites
