Below are two pancake sheath designs I am considering making for a friend. Before I go and waste leather, does anyone see any inherent design flaws that would make these a "no go"?
My friend is a big buy like me so I'm trying to make it ride pretty low on the belt and keep it from jabbing into his side all day. I plan on wet forming it to the tool so in the end the "pouch" part won't be rectangle but, it was just easier to draw out a rectangle. I was also thinking about hot dipping it because he is outside a lot hunting or working on his farm. Is hot dipping over kill? Tell me what you think!
  • Replies 28
  • Created
  • Last Reply
Top Posters In This Topic
G'Day,
Is this for a knife , as you mention hunting ?  I would have thought a good liberal coat  of oil...or two would be sufficient.
 I'm no expert, but it looks pretty good to me.
HS
' I have a very gweat friend in Wome called Biggus Dickus,
He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '  :rofl:
I think its for a multi tool but yes a good coat of oil should do it
I  would have to go with the top design  and I would even like a little more forward cant .... but that is just a personal choice . I think it might look more to my liking to drop the back side of the pocket arch but again just a personal preference .
I made a multitool pouch not long ago for a friend . . .
It lays along his belt . . .parallel to the belt . . . and he has no trouble with it.
That gets it up and out of the way of the pocket . . . and down and out of the way of any doughnut overlay that might happen :lol::lol::lol:
I wet molded it and gave it a good couple of coats of resolene . . .
He works in a steel mill . . . and he was tickled pink with it.
May God bless,
Dwight
www.dwightsgunleather.com
You say ; ride low on the belt'
To me those both look like high riders. I would take the upper-forward belt slot out further and up and the rear slot can move up and towards the sheath. Invert your drawings to see what I'm getting at
On 10/22/2022 at 5:32 AM, Handstitched said:
G'Day,
HS
Thanks! It is for a Gerber multitool but he carries that thing everywhere. Sounds like everyone agrees a couple of coats of oil should do the trick.
Thanks, Bert!
I'll take a look at that. I just bought a couple of pounds of veg tan scraps so I may have to make more than one just to try out everybody's ideas.
May God bless,
Dwight
I really like that idea Dwight! That's genius! Like I said above I just bought a few pounds of veg tan scraps so I'm probably going to try out a couple variations. I will let y'all see how they come out and how he likes them.
I think I see what you mean. Have the front belt slot even or higher than the top line of the sheath itself?
I had to go look . . . was not sure I took a picture of it . . . this was before it was finished . . .
But it shows how it is carried . . . belt loop is sewn to the back of it . . . you can see the stitches . . . and it was a pain to go thru all the layers and still keep the machine on track.
I'm not all that good a sewer . . . especially on little stuff like this.
But he was absolutely thrilled . . .
He wears in on the right side over top of his front pocket of his jeans.  Has no problem accessing the pocket.
May God bless,
Dwight
Edited by Dwight
