This is my fourth wallet. My first two were pretty but I think this one is worse but more complex than my first two.
  • CFM
it looks like a good wallet to me burnishing  the edges will make a ton of difference also using the same color thread will help as it hides any irregularities in sewing.
In addition to using the same color thread as Chuck mentions,  I think I would have used a finer denier thread.  The thread that you used seems a little too thick for my tastes.
I wild also suggest making sure your hands are clean or wearing nitrile gloves while stitching,  especially when using white thread.  There appears to be some body oil discoloration on the inside where you finished the stitches.
Other than that it looks like a good start.
    /dwight
I really like that design! As others have said above edge finishing goes a long way in making wallets like these look really finished.
On 11/13/2022 at 7:05 PM, Mulligan31 said:
Nice wallet Michael.
Thank you.
I will do better on the edge finishing.  I know that is something I need to work on.
    /dwight
It is actually a honey colored thread.  But you and Chuck are correct, using a black thread would have been better, especially since my thread is so thick.  The discoloration at the point where is finished the stiches is because I got my lighter too close :blink:
I will work on this.
That's one of the reasons that I quit trying to finish my stitching by burning the thread.  I wound up burning the project too many times.  Now I just back-stitch a couple holes and then use small thread scissors or a fine scalpel to cut the thread in the hole.  Looks clean and I haven't had any problems with the thread coming out.
I still recommend wearing nitrile gloves while stitching.  In addition to helping keep the project clean, I've found that I can get a better grip on the needles with the gloves.  Helps to reduce hand cramping after a long stitching session.
    /dwight
    /dwight
Last wallet I wore gloves. Made a big difference.
  • 2 weeks later...
do you have a layout of this wallet?
Virmer- large selection of laser engraving machines
