Cactusman
Flesh side slick finish
I tape the fleshside before tooling. Once finished when I remove the tape the fibers are loose no longer a tight even surface.  Hasn’t been a big deal … I slick it with gum and move on… until started doing bags. Now, I want a nice nice nice finished feel/look and not sure I am getting everything out of slicking that I can or want.
Why are the fibers so loose at the end of the tooling process when I pull the tape off?
Other than lining the leather, how best to finish the flesh side?
Thanks,
David
You could burnish it with a beeswax & carnauba wax mixture.
Warm the mixture, warm the leather, apply wax and rub well in whilst playing a hairdryer over it. Then burnish the heck out of it with a good rag
Are you using packing tape? I do and if so it can be bad, I see a lot of people use the blue painters tape that I don't think is quite as sticky and getting off it sooner then later.
I've done quite a few pieces with Tokonole. Just spread on thinly and burnish.
Take a sponge . . . lightly dampen the flesh side . . . LIGHTLY . . . and use a wide putty knife . . . or something similar to flatten the fibers . . . then a light coat of resolene . . . cut 50/50 with water.
Makes a nice finish . . .
May God bless,
Dwight
I dampen lightly and use glycerine saddle soap and  glass slicker .  Makes for a pretty good finish .
