Hi all toolers. Please share all your critique. This is about my 5th major tooling attempt.
thanks
One of the DG tooling patterns. Follow the shading on the vines and petals and if you don't have a wiggler use a veiner on some of the stems. You can watch the videos multiple times and pick up things you missed. Good start.
  • CFM
take your time!! What i see is you hurried through your work not even tooling some of your stuff. What i do when using a pattern from someone is make sure i have all the correct stamps first and a picture of the finished pattern. Most patterns that are sold have both a list of stamps and a finished picture. Then after studying the picture and the initial beveling do one thing at a time like one flower, study the way the tools are used in each petal from the picture take your time your in no hurry, if you make a mistake note it and make the change on the next petal always striving to make your work more precise smoother and clean you only get one shot at each stamp so be precise as possible to the picture before swinging the maul. Most folks do each stamp at a time and work through the whole design and is what i do now but for practice i suggest you finish each leaf, flower or whatever so you can see your progress  and make corrections as you go. Also work form the top down so you don't mush down everything under your arm lol. As you get more practice you will get better seeing the way the stamps create the effects of dimension and form in your work.
Good luck we all look forward to seeing your progress!!:)
https://www.youtube.com/watch?v=SXKarsdhVDQ
Practice swivel cutting to make smooth and uniform curves and eliminate the over cuts I see. I also see places where your pear shading doesn't follow the curves of the petals in your flowers. You also left too much of the design with nothing except the shape. With practice it will all come together for you.
Thanks everyone
  • CFM
20 hours ago, Burkhardt said:
yup Don makes it look easy, he has a lifetime of experience and watching his videos is a must but i still however like a still photo that i can set down next to my work and study as i tool. my pc is upstairs plus i did this video watch a bit stop it, re-watch, stop it, work a bit,  watch some more, repeat  learning to paint till i about went nuts. i found using a still photo brings back the memory of the video so I don't have to re-watch a dozen times.
I hear ya, that's why as soon as I seen it I recognized the pattern because I've watched the video ten times.
I believe he has a 4 part series on tooling with a free print out of the design so you can follow along
"It ain't about how hard you hit. It's about how hard you can get hit and keep moving forward."
- Rocky Balboa
