noidea
New member, new to me machine Sunstar KM-340BL
Hi All
I'm new from downunder and found this site like many others I guess do when searching for info on industrial sewing machines. My main reason for purchasing a machine was not so much leatherwork but for industrial sewing heavy vinyl / polycloth? fabric as one of my children is a trampolinist and I'm making extra safety padding for our home trampoline setup. I'm also interested in MYO outdoor gear and who knows if leatherwork comes up in the future.
Anyway enough about me I thought I would post up a pic of the machine I've just bought, its a Sunstar KM-340BL walking foot machine. Where I live walking feet machines at home hobbyist prices are few and far between so when I saw this on a local marketplace for $500 AU the quick google of the model number and spec sheet was enough to suggest it should do all I am looking for
 https://industrialsewingmachineman.com/machines/mach.asp?dir=sewmach&brand=SunStar&Model=KM-340BL&ProductType=Industrial+Straight+Stitch+Machines
The machine is made in Korea and from my limited experience seems very well made, no chinesium evident at all. For all of the experts out here is this a clone of something else, I can post more pictures if needed.
It came on a standard size industrial table with a 3/4hp slow speed clutch motor and being in Australia it's even better as its 1425RPM with our 50Hz power not 1725 RPM. I test sewed it at the sellers with multipe layers of fabric with the thread you can see in it and it stitched OK. For the time being I am just going to get a smaller motor pulley 40-45mm to slow it down a bit as its got a 110mm one on the motor but will work on a servo motor setup when I have saved a few more dollars as this is just a hobby for me so no doubt I'll be posting more in the future.
I have managed to find the spec sheet, user manual with all of the timing and adjustment info and also parts manuals that I can post somewhere if it will help anyone else.
Welcome aboard!
Post your manuals here.  If the files are too large, send me a PM and I'll give you an address you can send them to me at and I will post them for you.
On 11/19/2023 at 7:54 AM, Northmount said:
Welcome aboard!
Thanks, here's the datasheet I'll message you about the others.
KM-340BL datasheet.pdf
Added files
KM-340BL_MME manual.pdf
KM-340BL_PME parts book.PDF
Edited by Northmount
Added additional files from "noidea"
Looks like machine head been sitting around for several years, needs good cleaning and oiling maybe ? it looks neglected but not that rough.
Appears to be a Drop-feed Walk. nothing wrong with that feed, as you said Leather not your primary need. you are just limited to less selection of foot options with that feed .
For your said.. ' home hobbyist  needs ' like, vinyl, cordura, webbing.. etc.  it do pretty good . . should handle #69 E/t-70 and #92 F/t-92, and lighter weight threads .
Files added to your post.  Thanks
G'Day, welcome :)  I'm from WA as well, Central Wheatbelt. That machine looks like it just needs some TLC .
HS
Thanks for the comments, I bought the machine from a lady who ran a home business doing upholstery and other stuff who had upgraded machines. This was one of her old ones that had been in storage on her verandah so not being rained on but still exposed to the weather a bit. There's some rust on the chrome and metal parts but it should clean up ok and I looked at the price of tension discs and they were not expensive.
Nylonrigging do you know if the feet on this machine are the same as any of the other more common brands, I've attached a few more pictures.
I'm limited for space myself so the table will probably live in my carport and I'll store the head in my shed where it's better protected.
HS do you have an industrial machine? If you do where do you buy your consumables from, I'm in Perth.
Edited by noidea
To tag a member so they get a notification, do this:  Type the @ symbol followed by the users name, and pick the username from the popup list.  Then they are much more likely to get a notification.  Other method is to quote part of their post like I did above.
@nylonRigging
Yeh man, I have 4 machines all up, , including " Brutus" my  441 clone . I get all my threads  needles etc. from ' Sewing Machines Australia', they are  in QLD , on line, but you can chat  and order with them over the phone , and they are quite  helpful .  Not too many industrial machine suppliers in Perth, and what is available in Perth are not as good  and not as helpful ,according to those that have tried               ' other' suppliers.
HS
Pic. of your machine to get look at your feet . I not positive ? , looks/resembles the Consew Feet like a ( 205 RB )
but you might start your search for compatible Foot-Sets on Ebay . Low Price-$ sets to see if the Feet shanks are good to go for a match.to your feed .
Edited by nylonRigging
