wilsonintexas Report post Posted Wednesday at 05:42 PM short version. What oil pump works best on a I a Consew 220 (no walking foot no reverse) at low speed? long version: i bought a Consew 220. Not the best but what it is what I have. I have added a brushless motor where i can set the max rpm. This is working well. I normally run at 500-700 rpm. It also has a slow ramp so the motor is working well. At the low rpm and slow speed i never see oil out of the top tube. it is getting a little tight some mornings. when i start for the day i max the rpm at 22000 and run it until i see oil, then let it run 2-3 minutes. then i drop speed to 500 and work. The oil pump oil pump is a Centrifugal pump. I am sure at low speed it just does not create the pressure needed i have googled for a gear pump, which should work at slow speed. Consew makes some, but i never see a picture to know if it will fit. does anyone know the part number that would work? or am i ok running it at high speed to oil in the morning? i usually take this time to wind an extra bobbin? Quote Share this post Link to post Share on other sites
Constabulary Report post Posted Wednesday at 06:03 PM (edited) I´d oil it manually. IMO a different / new oil pump it too much fuzz for an old machine like this. It even has no reverse right? Just oil it manually as lets say a Singer 96K or similar. Edited Wednesday at 06:09 PM by Constabulary Quote Share this post Link to post Share on other sites
Northmount Report post Posted Wednesday at 06:48 PM 1 hour ago, wilsonintexas said: short version. What oil pump works best on a I a Consew 220 (no walking foot no reverse) at low speed? Moved your post to leather sewing machines Quote Share this post Link to post Share on other sites
CowboyBob Report post Posted Wednesday at 07:02 PM Yes,the best thing to do is try to run it high speed (like winding a bobbin) once a day until you see oil @ the window & you shouldn't have any problems.I went to an Amishmans place once & he had a Singer 241 that had a buttonhole attachment on it that he ran for quite a few yrs w/o using the oil pan. Quote Share this post Link to post Share on other sites
