Members Cumberland Highpower Posted January 8 Members Report Posted January 8 On my Consew 277r I noticed the feed dog mechanism is feeling loose. The dog and screw are new and tight w/locktite, but what it's bolted to is starting to feel sloppy. I took the covers off the end of the arm and looked it over. I cannot see any type of adjustment to take up the slop right away. I "think" i can see some screws on the back side of the slide plate but I cant really tell if that's what I'm looking at or not. The parts look pretty substantial, based on the size and hardness I can't imagine enough wear forming to cause the slop. Is there a way to adjust this out? Japanese machine, probably mid 1990s Quote
Northmount Posted January 9 Report Posted January 9 On 1/8/2025 at 9:06 AM, Cumberland Highpower said: On my Consew 277r I noticed the feed dog mechanism is feeling loose. The dog and screw are new and tight w/locktite, but what it's bolted to is starting to feel sloppy. I took the covers off the end of the arm and looked it over. I cannot see any type of adjustment to take up the slop right away. I "think" i can see some screws on the back side of the slide plate but I cant really tell if that's what I'm looking at or not. The parts look pretty substantial, based on the size and hardness I can't imagine enough wear forming to cause the slop. Is there a way to adjust this out? Japanese machine, probably mid 1990s Pictures might help get you an answer. Quote
Members Cumberland Highpower Posted January 15 Author Members Report Posted January 15 Northmount I got it resolved. I took about 3 hours today and looked it over/worked on it. The feed dog attaches to a plate that's dovetailed into another. The dovetail was adjustable for wear, but the screws (I thought I saw) that held the adjustable gib were on the backside. No access from anywhere outside of the machine. I had to remove the hook, and both of the feed dog motion shafts to get to the screws. I was a little surprised at the design, the adjustable gib was different from what's depicted in the manual/parts book that came with that machine. Quote
Members shoepatcher Posted January 17 Members Report Posted January 17 Stupid design it sounds like. glenn Quote
Members Cumberland Highpower Posted January 17 Author Members Report Posted January 17 20 hours ago, shoepatcher said: Stupid design it sounds like. glenn Yeah that was a pretty stupid part design in an otherwise fantastic machine. At least it was a good chance to tweak the feed dog height and centering....... Quote
