Members frots Posted November 30 Members Report Posted November 30 Hi, I have an opportunity to get a sewing machine Mitsubishi DN-275. My question is does someone use that machine for leatherwork? On thin leather yes it will probably work. I will not use very thick leather. Simple wallets etc.. Thanks in advance. Quote
Members nylonRigging Posted December 1 Members Report Posted December 1 I always keep a couple of double-needle needle-feed around. The Mitsu. dn-275, It will stitch thin leathers very nicely, it uses common found, inexpensive needle-gauge sets for changing it's set-up for what you might need, and if ? it has a split-needle bar that even better. It Not a industrial machine you want as your primary leather stitcher, like a good compound feed single-needle. So I assuming you have other machines already ? , Quote
Members frots Posted December 2 Author Members Report Posted December 2 I have one Singer 18-2, that is ment for different job shoes, slippers etc.. I want to keep 2 main machines. One being the Singer for its purpose(shoes, slippers etc..) Second one for flat surfaces wallets, bags. Quote
