I was given a silver buckle that has a 2" loop soldered on - no swivel. I think it is called western style with a simple peg clasp that goes through the hole in the belt. I want to buy a lether belt blank for it, but one that fits my pants has to be 1 1/2" wide. How do I attach the blank and keep it centered in the loop?
@StevePianoPlayer
You could get a short piece of 2" wide leather (around 2" long) , and wrap that around the loop. You then attach it to the 1.5" blank and make sure that it is centered.
The 1.5" strap will be sandwiched between the 2" piece. You can either sew it on or use a couple of rivets.
Brgds Jonas
Or fit a couple snaps so its interchangeable with other buckles , I do that on almost all of my belts. :)
HS
' I have a very gweat friend in Wome called Biggus Dickus,
He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '  :rofl:
  • CFM
The pin and hole in the center of the belt will center the buckle in front, plus the loop that holds the tongue on the back side will also center it.   Don't worry about it. Use it as is.
Edited by chuck123wapati
@StevePianoPlayer
Glad to be able to help 🙂
It is looking great, I like that you have cut the 2" piece so it follows the curve of the buckle. Good job 👍
Brgds Jonas
As @chuck123wapati said, the bar in the buckle typically has a v in the center to keep them in line. This allows buckles to used on several belt widths. You don't need to do anything special
I see that you've already come up with a solution🍻
Edited by DoubleKCustomLeathercraft
I post most of my work on IG now. Take a look if you want to see more
https://www.instagram.com/doublekcustomleather?igsh=NDI4enoyb3E2aDg1
God, hunting, fishing, chainsaws and leathercraft. Passions to live for
