AlZilla Posted March 31 Report Posted March 31 I didn't think this attachment through. I need to attach the strap on the picture to the patch. There will be 2 more of the same at the other end. These suspenders have a single strap on the back and 2 in front. I could lay the patch on the strap and sew it, but that gets really thick. I just can't visualize a solution that doesn't look clunky. Thanks for any ideas. Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
Members Mulesaw Posted March 31 Members Report Posted March 31 @AlZilla Could you make some sort of bleed knot to attach it ? Brgds Jonas Quote
CFM chuck123wapati Posted March 31 CFM Report Posted March 31 1 hour ago, AlZilla said: I didn't think this attachment through. I need to attach the strap on the picture to the patch. There will be 2 more of the same at the other end. These suspenders have a single strap on the back and 2 in front. I could lay the patch on the strap and sew it, but that gets really thick. I just can't visualize a solution that doesn't look clunky. Thanks for any ideas. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
CFM chuck123wapati Posted March 31 CFM Report Posted March 31 (edited) I used two rivets on each strap; they are about ten years old now. If it seems too thick skive down the attachment areas. Edited March 31 by chuck123wapati Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Members dikman Posted March 31 Members Report Posted March 31 The first pair I made I stitched all around 'cos that's what I thought you did (plus it looked very neat and tidy). It took a while but the inevitable happened and one strap tore across the stitch line. How did they make them in ye olde days? Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
AlZilla Posted March 31 Author Report Posted March 31 6 hours ago, Mulesaw said: @AlZilla Could you make some sort of bleed knot to attach it ? Brgds Jonas Hmmm... This is about 8 or 9 ounce leather. I think a bleed knot would be hard. But I like the idea. Definitely going to think. Thanks. Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
AlZilla Posted March 31 Author Report Posted March 31 5 hours ago, chuck123wapati said: I used two rivets on each strap; they are about ten years old now. If it seems too thick skive down the attachment areas. It is too thick but maybe I could skive the flesh side and put the straps on top as you show. Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
Members Mulesaw Posted March 31 Members Report Posted March 31 15 minutes ago, AlZilla said: Hmmm... This is about 8 or 9 ounce leather. I think a bleed knot would be hard. But I like the idea. Definitely going to think. Thanks. I meant that the bleed knot should be made from something thinner. Maybe a better word is lacing. Like the back belt on a set of chaps. 🙂 Brgds Jonas Quote
AlZilla Posted April 16 Author Report Posted April 16 So, here's where I ended up. Narrowed them down, skived them, then glued and sewed a stitch line. Thanks for everyone's thoughts. I'm still trying to figure out how to incorporate bleed knots into suspenders ...😎 Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
Members nylonRigging Posted April 16 Members Report Posted April 16 Spreader Bar 3-way Connector - Quote
