hi,
I am looking for to make a few sets of leather shoulder straps with sewn on felt padding for a reproduction back pack . please see attached photos. leather is 2-3mm thick.
Looked at your website ( alpineluddites.com ) and wonder why you need someone to make straps for you?? All you need is a utility knife, a hammer, few rivets, rivet setter, some leather, some felt as you already have the sewing machines.
kgg
  • CFM
Is it felt or sheepskin?
kgg
yes, i could, but i don't have the experience and i need them to look better than i can make them. i don't have the dies to cut the ends round, and i would rather hire someone than have mediore results.
felt.
On 4/4/2026 at 7:49 PM, alpine luddite said:
felt.
I wouldn't have any problem making them . . . I've just never really worked with felt.  Where do you get it . . . how thick is it . . . are there different grades???
May God bless,
Dwight
www.dwightsgunleather.com
Yes there are different grades, quality, types, thickness and cost of felt.
Felt is:
i) Made with fibres that are basically tangled together rather then woven together using heat, moisture and pressure.
ii) Basically there are three types. Those that are made with Natural Wool, Synthetic Fibres and Blends of wool and man made fibres.
iii) As far as how thick for a shoulder pad it will depend on it's usage ranging from 1/8" to 3/4". The felt strap in the photo looks to be very thin felt.
I did notice the edges of the felt were pinked. Depending on the age they were probably pinked with a hand crank Singer pinker, pinking shears or a rotary cutter with a pinking blade. This was probably done to reduce shedding of loose fibres so you only get small pieces rather then long stands being shed as a result of wear.
Fair enough.
kgg
felt.
How thick would you want the felt to be??  And would you want all wool felt?
May God bless,
Dwight
Are you still with us  ??
May God bless,
Dwight
