Contributing Member friquant Posted July 27 Contributing Member Report Posted July 27 What is actually meant by the term Domestic Sewing Machine? How do they differ from an industrial sewing machines? Last winter I took on a few domestics, and in the process of repairing them spent lots of time mulling over what actually makes a domestic sewing machine. This is what I came up with: A. For Dainty Fabrics Typically capable of making short stitches with small diameter needles. B. Inexpensive Typically do NOT come with a knee lift. (knee lift adds expense but optimizes for productivity) C. Suitable for low duty cycle sewing Put your domestic machine on wide zig zag, then run it at full power for five minutes and see how warm the motor gets D. Takes up Less Space Sometimes considered portable. (stash it away in a closet, bring it out when you need, or take it for a day trip) Other times built into a fold-out cabinet/table such that you have the full width of the table when you are sewing, but when not sewing you can collapse the table and put the machine out of sight. (Who would really want their sewing machine out of sight??) E. Portable Can buy one as a gift and bring it home in the family sports car. You don't have to be all that strong to lift the machine. F. Non-Scary Motor must start up in gentle fashion. (Low power and heavy flywheel definitely accomplish this) As a matter of fact, one manual I read said "to begin sewing, give the handwheel a push and step on the gas" Must run on common household voltage. Motor is typically low power. Top speed is often (only) 600-800 rpm. Sometimes the belt is completely covered (for safety?) G. Multi-Function Often comes with zig zag which allows you: - button holes - pretend overlocker - stretch fabrics Sometimes includes other stitches as well. H. Uses Common Needles Not sure if this was intentional, but domestic machines mostly all take the same needle system, which makes shopping for needles easy for non-educated home users. I. Motor Included The motor and foot pedal are part of the unit, and are preassembled. (industrial machines, to the contrary, come separate from the table, motor, foot pedal, and all must be configured on location) J. Plastic Gears are Tolerated (This might belong under "inexpensive") Note for industrial machines, longevity is key. For this point, one could say a domestic machine is a "toy" machine since it doesn't have to last. K. Easy to Use Typically have flat-shank needles which are straightforward to install. Light force is sufficient to raise presser foot Tension dials are often numbered 1-9. - ?? Are these easier to thread the top?? - ?? Are they easier to thread the bobbin? L. No Capability for High Needle Thread Tension (This is actually a non-feature. You will only notice this non-feature when you try to sew outside the envelope of the typical domestic.) Note to have high needle thread tension, you may end up turning the adjustment screw all the way in. Then when you lift the presser foot, it won't actually release all the tension from it and it will be difficult to pull the material from the machine. (Note ideally when a tension disc adjustment screw bottoms out, there would still be some available spring travel under it...that way when the presser foot is lifted it has somewhere to push the excess spring to release the tension) M. No pins to wrap the thread around at the top For large thread having an extra pin at the top around which to wind the thread (to keep it from forming loops before it gets to the tension discs) is ideal. Those pins are common on industrials, but uncommon on domestics. N. Comes with a spool pin That is, intended to be used with small (300m) spools of thread that can be machine mounted. (To go bigger means you would need a thread stand, which would cost extra and require setup and would not be portable.) Quote friquant. Like a frequent, piquant flyer. Blog: Choosing a Motor for your Industrial Sewing Machine
AlZilla Posted July 28 Report Posted July 28 You're way over complicating it. Domestic just means intended for the home market. Singer had Class 15 and 66 machines labeled and marketed as both Domestic and Industrial. Now, how about that meaningless term "Semi Industrial"? Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
CFM chuck123wapati Posted July 28 CFM Report Posted July 28 Not all domestics were made the same. My Singer slantomatic 401A has all-metal gears and 25 diferent stitches. Going on 70 yrs old. The majority of the newer ones are junk compared to it, imo. The invention of the domestic and Singer's first-of-its-kind installment plan for purchasing literally gave women the ability to start a home business, and thousands were taken out of poverty because of them. One of the world's greatest inventions imo. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
kgg Posted July 28 Report Posted July 28 17 hours ago, friquant said: What is actually meant by the term Domestic Sewing Machine? 1 hour ago, AlZilla said: You're way over complicating it. I agree. 9 minutes ago, chuck123wapati said: One of the world's greatest inventions imo. I agree. Domestic just means basically home. Domestic sewing machines just means home machines made to withstand normal home use. That said some of the old classic's still outdo most of the new junk on the market. A lot of Domestic Singers were actually scaled down versions of their Industrial sewing machines at a reduced price. Which was a great way of getting sewing machines into homes particularly in remote areas and in some cases adding extra income to the family. Example: The classic Singer 15-91 was a scaled down version of the Class 16 which was about 20lbs heavier. In my opinion, you got two class of sewing machines. Domestic and Industrial all other labels is just hype. 1 hour ago, AlZilla said: Now, how about that meaningless term "Semi Industrial"? You forgot some of the other advert buzz words to sell Domestic sewing machines to the general public. i) Heavy Duty ii) Professional Grade iii) Semi-Industrial iv) Commercial Grade v) Sews Leather vi) Workhorse vii) High-Speed viii) High-Performance Motor ix) All-Metal Gears x) Enhanced Piercing Power kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Moderator Wizcrafts Posted July 28 Moderator Report Posted July 28 Domestic sewing machines were a major part of the industrial revolution. They made it possible for the average person to make and repair their own clothes. I used to buy, repair and resell old iron body Singer sewing machines, some of which were built in the late 1880s through the early 1900s. The ancient oscillating bullet shuttle mode 27 and 127 outperformed the later models 15 and 66 when it came to sewing leather. I upgraded the motors and foot pedals. I would use some of those machines in my leather shop when I needed to sew thinner work that my walking foot machines tended to consume inside the hole in the feed dog and its throat plate slot. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Contributing Member friquant Posted August 2 Author Contributing Member Report Posted August 2 On 7/28/2026 at 12:25 PM, Wizcrafts said: I upgraded the motors and foot pedals. What kind of motors did you put on them? Quote friquant. Like a frequent, piquant flyer. Blog: Choosing a Motor for your Industrial Sewing Machine
Moderator Wizcrafts Posted August 4 Moderator Report Posted August 4 On 8/2/2026 at 12:54 PM, friquant said: What kind of motors did you put on them? I think they were called AlphaSew, or something like that. The foot controllers were solid state, unlike the originals that moved a metal rod inside a coil. The motors drew 1.5 amps if I recall correctly, which was about triple what the original motors drew. This translated into more power from the motor the the balance wheel pulley. They were bought online. The machine power plugs were either universal or specific to one machine model. Send me a private message if you want a link to them. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
