This is a project I did about 6 months ago, and it was my first try on stamping leather.
I'm a hobbyist with a scope problem. Every finished project needs a skill I didn't have when I started it.
You can follow my projects on my personal build log: https://silfer.works
Really nice looking belt! Very precise stamping, and I like how you have the clean ending between the stamping and the smooth leather.
Riley Alfred, Proprietress
Alfred Leatherworks
[email protected]
Very nicely done!  Very clean stamping, stitching looks perfect. A very solid belt.
The use of 4 Chicago screws on the buckle strap is a different twist; looks solid.
20 hours ago, Silfer said:
...it was my first try on stamping leather.
Now you're making me angry :rofl:
It's great work! The only change I would do is the hole for the belt buckle tongue. If you use an oval punch instead of a round one the tongue will sit better and the belt will lay flat.
The oval hole is absolutely a learning from this. I didn't own one, so round it was at this time ;)
Nice looking belt:You_Rock_Emoticon::thumbsup:
Very nice work.  I find it interesting that you only have one hole.  You don't plan on gaining/losing any weight?  I have to change holes on my belts on a weekly basis. 😁
I'm also interested in you technique for attaching the buckle.  Can't say that I've ever seen a belt sandwiched between a separate strap for the buckle attachment like that.  I may have to give that a try on my next belt.
That one hole is my index: If it starts feeling tight, then it is time eat less. If there will ever be two holes, the new hole will be on the "right" side ;)
Oh, and the buckle attachment is simply the culprit of me not knowing what I'm doing. This seemed to be logical for me, so that's the design I went with. I'm sure you can see similar weird solutions in my other projects too because I simply don't know what's "normal".
Sometimes on nicely finished belts that are not made-to-measure, this is the way to go for adjusting an off-the-rack belt to a specific person: loosen the screws, cut the belt to length on the buckle side so that the tongue fits the middle hole on the person wearing it, punch a new hole (or holes) for the buckle attachment and reattach the buckle.
The belt for my wedding costume was cut to length this way ;-)
The belt for my wedding costume was cut to length this way 😉
That makes perfect sense. I’ll take it back; I absolutely knew what I was doing, hahah :thumbsup:
