What is the best way to finish a row of hand stitches? I have been tying a square knot heating the knot slightly with a match then pulling the knot into the last stitch hole. How secure do you think this method is? Is there a better way? One problem I have had is getting the finishing knot to go all the way into the last hole. All thoughts appreciated.
Mark
Stitch back a couple of stitches or when you have sewn around an item and end where you started, just stitch over a couple of stitches. Cut off the threads off close and poke the ends down into a stitch hole.
Barra
I'll add that I use a drop of thinned PVA white glue, run down a toothpick into the hole after the thread.
Badger
