Members Nomad Posted October 28, 2009 Members Report Posted October 28, 2009 (edited) Hi, All. I have made it for test, and probably I use in one of projects. Used spirit dye for the background, one coat Neatsfoot Oil, two coats Tan Kote, Fiebing ` s antique and atop again Tan Kote. After that one coat Aussie Leather Conditioner. Each time I allowed to it to dry days if it is necessary, but in the end it did not become waterproof, there are divorces. I will be glad to comments and any help. Thanks. Nomad. Edited October 28, 2009 by Nomad Quote
Contributing Member ClayB Posted October 29, 2009 Contributing Member Report Posted October 29, 2009 It turned out looking pretty nice Nomad. I hope that somebody can help you with the "waterproof" finish problem. Quote ClayB Badlands Leather Art blog Badlands Leather Art Website
Members anester05 Posted October 30, 2009 Members Report Posted October 30, 2009 (edited) The only finish that I know of that is water proof is a lacquer based finish. The acrylic finishes are just water resistant and the tan kotes are not really either its just a finish. I know from experience that the acrylic finishes will wipe off with enough moister. The spray on finishes you can buy are water proof but I have had these crack on me. A waxy finish will also be water resistant but I haven't used these so I can not tell you how well they work. One thing I am going to try is a tan kote to get the look then finish that with Saddle Lac for water resistance. I was told if you use a spray on finish to spray it on in thin layers and let each layer completely dry before spraying on a second layer to stop the cracking. Hope this helps Edited October 30, 2009 by anester05 Quote
Members Nomad Posted November 3, 2009 Author Members Report Posted November 3, 2009 Thanks, I will try still. Quote
