Looking for a hot stamp machine for leather imprint
Hi,
I am looking for affordable hot stamp machine for some light duty stamping on leather.
Anyone know where i can find one.
Kindly contact me @ [email protected]
Thanks
Anthony
  • Ambassador
THE ONLY PLACE I HAVE FOUND THEM IS E-BAY ..........AFFORDABLE ????? A VERY HIGH DOLLAR
BUT KEEP LOOKING
Luke
  • 1 year later...
I used a hot stamp machine to put lettering on the spines of books. The heat activated and transferred the foil. For just stamping leather do you need the heat? The machine I used was pricey.
  • 1 year later...
Hi,
Thanks
Anthony
Hi,Anthony, how about this,see the attachment.
Technical Parameter:
1.Gilding area:210*290mm
2.Area of the worktable :400mm*320mm
3.Max. pressure:4000Kg
4. Up and down throw:40mm (Can be increased to 80mm)
5.Power of heating :1000W(According to gilding area)
6.Paper feeding method: Motor driven
7.Temperature range: Room temperature -300°C
Product advantage:
1. Electric controlled operation.
2.Heating temperature is stabilized by temperature controller.
3.Vertical pressure crankshaft design which gives powerful pressing force.
4.Adjustable hot stamping pressure, temperature and speed;
5. Multi-orientation and angle adjustment of the worktable.
6.Adjustable automatic paper feeding and receiving.
7.Photoelectric celled can be installed for pitch control according to requirement.
8.Worktable height can be adjusted freely.
Product description:
The workpiece is loaded and unloaded manually. Full automatic processing; steel plate base, smooth gilding process; vertical pressing force; it can realize gilding, impressing and
embossing of paper, plastic, leather, PVC and wood products.
post-27642-020084700 1325246455_thumb.jp
post-27642-032142000 1325246581_thumb.jp
Edited by david116
