Members woolfe Posted August 21, 2010 Members Report Posted August 21, 2010 Hi all, I got an order for a mag carrier for a 9mm Kimber pro carry II. I'm wondering if the mag dimensions are the same as a 1911 mag for 45 acp. I know Colt new agent 9mm mags where roughly the same as 45 acp mags. Anyone know about the kimber? Thanks a bunch! Quote http://www.woolfegunleather.com/
Members Tac Posted August 21, 2010 Members Report Posted August 21, 2010 (edited) They are the same as the Colt mags. Both have a pressed in rib that run down the inside of both sides of the magazine to center the smaller rounds inside the same diamerer mag body as the .45. Any mag for a .45 should work fine. The only exception to this would be the Springfield EMP 9mm 1911, as it has a reduced size magazine. -Tac Edited August 21, 2010 by Tac Quote -Tac "Well, I guess we did our good deed for the day Mayor"-Wyatt Earp "Tombstone"
Members woolfe Posted August 21, 2010 Author Members Report Posted August 21, 2010 They are the same as the Colt mags. Both have a pressed in rib that run down the inside of both sides of the magazine to center the smaller rounds inside the same diamerer mag body as the .45. Any mag for a .45 should work fine. The only exception to this would be the Springfield EMP 9mm 1911, as it has a reduced size magazine. -Tac Thank you! Quote http://www.woolfegunleather.com/
