Hi Everyone,
I was wondering if anyone runs a Seiko TH series machine?
I have a problem with mine at the moment - it's stripping the top thread!!
This has only started since I tried some proper leather needles, unfortunately they were too small & I ended up reverting back to my original needles, now it's stripping all the time.
So far, I have checked needle bar setting, & also noticed that the shuttle hook is catching the thread half way through it if that makes sense (this is causing the stripping).
I have adjusted the bobbin carrier right up to the max so that it just passes the needle.
Now I'm stumped.
Anyone got nay ideas?
Dave
P.S. Unfortunately I don't have a manual for it.
  • 2 weeks later...
Still stuck on this folks.
The sewing machine repair man let me down - never even turned up!!!
Tried needle bar height again & also polished bobbin hook but all with no luck at all.
The thread is now constantly being 'cut' as it goes through the leather.
Anyone help with this?
When you time the hook do you have the needlebar go up 3/32"before the point of the hook is at the needle?
I cannot thank you enough.
Back up & running now which has save my hands.
Dave
