RFMarsh
Leather Needles
I bought a refurbished Singer 201 for light leather projects and it seems to work beautifully. But, the leather needles I got (Organ, 15x2, 140/22) seem to leave a hole that is slightly at an angle to the line of stitching. I've checked several times to make sure that I have the flat side of the needle top facing left. Is this the way the needle is designed? or, am I doing something wrong?
That's the way it's supposed to be. You can use smaller stitches and not cut the leather, if the needle went straight with the stitch line, you could cut the leather. Besides, it looks better.
Kevin
Thanks, Kevin. I suspected that, but an old saddle maker in the area said it looked wrong.
Out of interest, what size thread are you running in the 201?
I've been using 138 bonded poly which, I think, is the max that the largest needle for the 201 (sz. 22) will take. It does a nice job up to about two layers of chap leather:
post-22845-011267200 1315844638_thumb.jp post-22845-064675600 1315844643_thumb.jp
