Sandman0077 Report post Posted December 27, 2012 Hello again everybody! I've come straight to the source because you guys have never let me down. I've been planning on making quivers for archery, and I ran into a problem that I didn't quite see coming. I didn't anticipate th difficulties of trying to sew long stitch lines down the side of the quivers. I googled for this, but all I really found were either the lacing method or ones sewn on sewing machines. How is this possible? I wanted to make one similar to this (Image from Rasherquivers): How can you machine sew that long stitch down the center like that? I must be missing something. Experts, please chime in! Thanks! Quote Share this post Link to post Share on other sites
tnawrot2 Report post Posted December 27, 2012 You will need a sewing cylinder sewing machine that sews up the cylinder, like a Singer 11-17. http://parts.singerco.com/IPinstManuals/11_17.pdf Quote Share this post Link to post Share on other sites
Dwight Report post Posted December 28, 2012 Might I suggest that you use your sewing machine to make the holes, . . . and then add the thread by hand sewing? I have to do this occasionally, . . . and it really does not take all that long when you get the hang of it. I use an old sail needle (that's what we called them on my Navy ship) which is a wooden handle, a small bobbin spool, and the needle all in one package. Tandy leather stores sell them. As large as that quiver is, . . . I would use the sail needle inside, . . . and loop my thread outside to make the stitch. I would think something in the neighborhood of a half hour for that one long stitch in the picture you show above. Another choice would be to simply contact cement it to a very thin piece of plastic tubing, . . . which in all honesty, . . . is very much most likely my choice. I know a fellow that does fly rod cases, . . . and I believe that is his process. May God bless, Dwight Quote Share this post Link to post Share on other sites
ACarver Report post Posted December 29, 2012 I did one before using butt joint...but it needs practice... you can refer to Al Stohlman book the Art of Hand sewing Quote Share this post Link to post Share on other sites
