Just bought a new airbrush, a Paasche dual action siphon feed model. I want to spray some fiebing's pro oil dyes. What can I use to clean the airbrush after using the pro oil dyes? Do I need to dilute with denatured alcohol? Thanks Alex
I usually clean with isopropyl or denatured alcohol. You'll definitely want to start with a diluted mix of 50/50 for your coloring. Lightly oil your piece first and then go over it with 50/50 dye/alcohol (or, if you're color is already 50/50, do 25/75). This will help the leather pull in the color so it actually absorbs better.
