Greetings from WV,
I am having problems with Mission Grain pig lining used in wallets. The finish sticks and rubs off onto the wallet contents. Someone who has one of the wallets i made won't use it because of this rub-off. Don't want to sell wallets that have this problem. This is the leather i am using; http://springfieldleather.com/32400/Lining%2CMissionGrain%2CBrn%2CRegula/.
Jesse
What are you using to seal in the dye? When the dye is dry, buff it really well until no dye is coming off on to the cloth, then I would suggest to use Resolene (50/50 mix with water) to seal in the dye.
I just use the leather as is; it comes pre-dyed and finished. Here's a couple photos of the wallet i use.
In this photo, i circled the areas on the lining that have the most finish rubbed off.
post-14947-0-05057900-1374247764_thumb.j
And here is what the finish has rubbed off onto.
post-14947-0-15362300-1374247785_thumb.j
Is this normal wear, or is there something wrong with the leather's factory finish?
Jesse
