Chief31794 Posted June 21, 2014 Report Posted June 21, 2014 Don't get many requests for a clutch purse, but occasionally someone will order one. I put this one out recently. Chief Quote
Members Rohn Posted June 21, 2014 Members Report Posted June 21, 2014 That is a beauty! Very nice work. Quote
Members MonicaJacobson Posted June 24, 2014 Members Report Posted June 24, 2014 I almost missed this one. Very nice! Quote
Members Wild Bill46 Posted June 29, 2014 Members Report Posted June 29, 2014 Man -O -Man CHIEF, This is a beautiful clutch purse, Great looking tooling, and lacing. True to the artistry I have always seen from you, keep it up, Quote
Chief31794 Posted June 29, 2014 Author Report Posted June 29, 2014 That is a beauty! Very nice work. Thanks Rohn. I almost missed this one. Very nice! Thanks, I appreciate the nice comments. Man -O -Man CHIEF, This is a beautiful clutch purse, Great looking tooling, and lacing. True to the artistry I have always seen from you, keep it up, Thanks Wild Bill. Chief Quote
Members DoubleC Posted June 29, 2014 Members Report Posted June 29, 2014 Chief, that's beautiful. Cheryl Quote
Contributing Member Samalan Posted June 29, 2014 Contributing Member Report Posted June 29, 2014 Chief that sure is nice work!!! Quote
Chief31794 Posted June 29, 2014 Author Report Posted June 29, 2014 Chief, that's beautiful. Cheryl Chief that sure is nice work!!! Thanks, both of you. I appreciate the nice remarks. Chief Quote
Members oscar621 Posted July 1, 2014 Members Report Posted July 1, 2014 That's amazing! but how? I can't figure out in what order you did the tool work and dye? Will you share? Quote
Chief31794 Posted July 2, 2014 Author Report Posted July 2, 2014 (edited) That's amazing! but how? I can't figure out in what order you did the tool work and dye? Will you share? Oscar, I'm a little confused, if you mean basically how I accomplished the look, it is: Cased the leather (See Bob Parks Post in "How Do I Do That" forum on properly casing leather) Transfered the designs to the purse, in this case I used a craftaid, but it's nearly as easy to do with a tracing on tracing film. Cut the lines of the design with a swivel knife Used Barry King Thumbprints to put the depressions in the flower petals. Used Leaf Liners on the leaves Used Flower Centers on the center of the flowers. Used stops on the bottom of the petal lines Used a veiner to decorate the leaves Uses a lifter on the center of the outside of the petals. Beveled all lines Cut decorative cuts with a swivel knife Cut the edge of the leaves with a swivel knife to give them the "jagged" appearance. Let project dry thouroughly Applied Tandy Saddle Tan Gel Antique (the only tandy staining product that I use) very liberally, rubbed it in well with a sheepskin pad) Allowed to dry somewhat, then wiped with paper shop towels lightly to remove excess antique paste leaving the residue in the depressions. Allowed the project to dry thouroughly (24 hours) Applied two light coats of Pure Neatsfoot Oil, allowing about 4 hours between the coats and then waited till the next day for it to settle and smooth out. Applied two coats of Clear Lac to seal the project. Allowed to dry for another 24 hours. Laced it using a double loop stitch with high quality lace. Hope that helps, Chief Edited July 2, 2014 by Chief31794 Quote
