yoji Report post Posted November 25, 2014 hi all Will be in paris within couple of weeks so why not to by some french tools. I will buying the edge glazing tool (fileteuse manuele) from mando as some others did. But i don't really understand why the price difference between the single and double tool is so high. The one with the single handle cost 170 euro and the double one is 470 euro. So why should i buy the double instead of buying two single handle units? Also i have asked mando about the beraud paint, but they do not carry it. They are selling another brand, they call it varnish 600 and it is around 18 euro for 1 litre. They talled me it is currently used by louis vouitton, goyard and on some hermes products. I know that hermes uses mostly stahl paint but i couldnt find any retailer for it. Did anyone used the paint from mando? Also i would like to purchase some different fancy colors but i dont need 1 litre of it. If anyone wants to i can pour the paint in 250ml/500ml plastic bottles and ship it to you.. Let me know Quote Share this post Link to post Share on other sites
yoji Report post Posted November 26, 2014 (edited) Alright i have found a korean website who sells this edge tool. He explains that the double handle version works between 0-20 Volts and has 190 watts unit. And the single handle tool works with 0-16 volts , 48watts power. Both units are heating up to the same temparature ranges. I do some soldering annd i know that using a more powerfull soldering iron will give more consistant temperatures since the unit heats up in a fraction of a second once the temperature drops due to heat transfer to the material you are working on. I dont know how relevant is this for the leather. Any ideas? Edited November 26, 2014 by yoji Quote Share this post Link to post Share on other sites
naz Report post Posted December 1, 2014 hi yoji, I would be interested in the paint from mando, have never tried it, please let me know if you can make it available. thanks & bon voyage Quote Share this post Link to post Share on other sites
yoji Report post Posted December 2, 2014 @naz: Sure no prob. will contact you a week or so before i fly to france. How much you want? I think i will fly to paris with some empty plastic bottles so i will not need to source them in paris. Quote Share this post Link to post Share on other sites
Sticks Report post Posted March 2, 2015 Hi guys, I too would very much like to buy some of this edge paint. Did you acquire some of it.? Pls let me know how to contact you if you have. Barry Quote Share this post Link to post Share on other sites
hitokiri8 Report post Posted April 17, 2015 (edited) Hi guys, I ended up buying some stuff from Mando including Black, Cognac and Grey edge paint. I have more than I can use and would happy to divvy some up into smaller containers (I have 4oz containers available to me) to sell. Feel free to PM me if interested. Edited April 17, 2015 by hitokiri8 Quote Share this post Link to post Share on other sites
skylosttears Report post Posted May 14, 2015 Alright i have found a korean website who sells this edge tool. He explains that the double handle version works between 0-20 Volts and has 190 watts unit. And the single handle tool works with 0-16 volts , 48watts power. Both units are heating up to the same temparature ranges. I do some soldering annd i know that using a more powerfull soldering iron will give more consistant temperatures since the unit heats up in a fraction of a second once the temperature drops due to heat transfer to the material you are working on. I dont know how relevant is this for the leather. Any ideas? Can you share some of Korea's Web site ? Thank you. Quote Share this post Link to post Share on other sites
byrova Report post Posted June 13, 2015 If you buy two small units is better than buying the double unit because if something goes wrong with the machine you would have to send it back to get fixed, if you have the singles and one goes bad you have the back up and be able to keep working. In reference to the paint I use and italian brand line that has more options to achieve a better result with the edges, but is all about preferences. Quote Share this post Link to post Share on other sites
yoji Report post Posted June 13, 2015 (edited) No way buy two single units. Single unit and double are very different products. There is a reason why the double unit version is is triple price than one single hand unit. The power outputs are different and this is what makes a huge difference. I have disassembled the unit my self to check the components. The unit is very simple and very high quality components used during production. Anyone with mediocre electronics knowledge can fix the units without problems. What makes these units pricey is the transformers. The transformers in these units are made in USA. That's what makes them pricey. Edited June 13, 2015 by yoji Quote Share this post Link to post Share on other sites
byrova Report post Posted June 15, 2015 Can you elaborate on the difference between the two I thought that V out was 20 V and 16 V, maybe you already know something that no one knows about the equipment. Thank You Where did you buy yours?? Quote Share this post Link to post Share on other sites
yoji Report post Posted June 16, 2015 I will just copy/paste what I wrote earlier since this is the answer to your question: "the double handle version works between 0-20 Volts and has 190 watts unit. And the single handle tool works with 0-16 volts , 48watts power." The transformers used in the double unit are more powerful than the single one. This is what makes the whole difference. And well this is a huge difference especially when you burn edges. The single unit is good for creasing. Not so for edge finishing. It can't keep up with the continuous heat transfer to the material on high temps. There is a reason for it being cheaper. And as I said before. It is a very basic u it. No complicated electronic parts. So the concern for sending it back to get it fixed should have no part on ones decision for which unit to purchase. Such a heavy piece of machinery even if it is a single unit, it is not cost effective to send for a repair anyway due to high shipping cost back and forth. Same quality replacement transformer should cost between 60-100$ depending on the power output. And this is probably the only part that will blow up. Maybe a transistor or two if you are using it heavily Quote Share this post Link to post Share on other sites
