Kassidy
Wire Marked Hide
Just wondering if these are wire scars on my hide I've been working? Also is there any way to tell if the hide is wire scarred before you work it?
Thanks in advance
Kassidy
post-40107-0-16922100-1441245111_thumb.j
Edited by Kassidy
Those look like wire scars. There isn't much way to tell beforehand unless they are fresh. They don't tend to bother much unless they are from a deep cut. If you have a chance to get dairy hides rather than beef they will usually have fewer scars & brands. Buck
I wasn't ignoring you Kassidy, just haven't been on for a few days. It's hard to tell looking at a photo. If they aren't deep, they shouldn't. If you bend the cased hide at the deepest one you should be able to tell. If it bends more easily along the scar than the surrounding hide does they will be weaker, but are probably still ok for other items. My best guess is they won't give you any problem. Good luck. Buck
