Members AussieMade Posted July 22, 2016 Members Report Posted July 22, 2016 (edited) This is my first....well second project I have completed after having 16yrs off. The first was a belt which I am not overly impressed by, but the second I made a collar for my dog. I am a bit happier with the final result, still a lot of work to perfect my stitching. And it's my first time using stamps as well. I am happy with how it turned out though. I know my edges are not the best as I have not used a proper edge beveller as I am waiting for one to arrive. Also sorry about the poor quality, I have not got the best camera, And he collar has been worn, so there are a few marks on it already. Let me know your thoughts. I need the good and bad as that will help me in the future. Thanks all. http://s1129.photobucket.com/user/dee_jay_8210/slideshow/Leather Work Edited July 22, 2016 by AussieMade Quote
RockyAussie Posted July 25, 2016 Report Posted July 25, 2016 Not too foul AussieMade and the buckle is very a very nice pick. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Members Tinbender Posted August 11, 2016 Members Report Posted August 11, 2016 Great work! I think that there could have been a better termination at the "tip". I always start with the tip on my strap projects and end at the buckle, just in case i dont have a good overall length. Make sure to use some kind of adhesive (Barge Cement) at your stitched area to help keep it all together. Keep your awl straight all the way through, and check the back to see how you are doing. I hope this helps! Quote
Members Halitech Posted August 13, 2016 Members Report Posted August 13, 2016 overall, nice job for your second project. Few tips though 1. Pick up a burnisher. Wet the edges then rub them with the burnisher. It will make them look a lot smoother. There is a great guide by Hidepounder in the how to section for more info 2. try not to sew across the leather. Some will say it doesn't matter but it it does weaken the leather some and depending on the application, could cause the leather to break 3. Use a wing divider (if you don't have one, good advice to get one) to line up where the holes (and edges) should go. Quote Every day you learn something is a good day. If you don't learn something every day, was it worth waking up for?
