lostcaggy
Removing marks
I've just started making a couple of leather wallets and was trying to bevel the edges. I slipped a couple of times with the beveler and marked the grain side of the leather. The leather is vegetable tanned coloured. Is there a way to remove the marks.
Thanks
Depends how deep the marks are. You can try dampening the area and working it with a modeling spoon.
You can try a fine grade sandpaper. I use 250 grit and sand as easily as possible.
I have used a fine brass Dremel wheel applied very lightly.
You can always incorporate your 'slip' into the design so it looks deliberate:)
Sam
